2811 vwic-2mft-t1 for 2 remote sites
lkatsaros
this is have a preliminary config on a cisco 2811 with one t1 wic on slot 0
and a vwic-2mft-t1 on slot 1.
i want to split slot 1 interface to
2 resite I a ordered 2 PPP circuits.
The one site on s0/0/0 we are installing an Avaya 350 gateway.
is the config for the vwic-2mft-t1 correct?
ersion 12.4
hostname RTR-001
boot-start-marker
boot-end-marker
card type t1 0 1
no logging buffered
enable secret 5
no aaa new-model
resource policy
clock timezone PCTime -6
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no network-clock-participate wic 1
ip subnet-zero
ip cef
ip domain name domain.local
ip name-server 10.1.0.10
ip name-server 10.5.0.5
username XXX privilege 15 secret 5
controller T1 0/1/0
framing esf
linecode b8zs
channel-group 0 timeslots 24
controller T1 0/1/1
framing esf
linecode b8zs
class-map match-any AvayaControl
match ip dscp ef
class-map match-any AvayaVoice
match ip dscp ef
policy-map xxx-Avaya
class AvayaVoice
priority 280
class class-default
fair-queue
random-detect dscp-based
interface FastEthernet0/0
ip address 10.1.0.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.5.0.46 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
description PPP to xxx
ip address 65.x.x.x.255.255.252
encapsulation ppp
interface Serial0/1/0:0
ip address 65.x.x.1 255.255.255.252
encapsulation ppp
interface Serial0/1/1:0
ip address 65.1.15.1 255.255.255.252
encapsulation ppp
router eigrp 100
network 10.0.0.0
no auto-summary
ip classless
ip route 10.1.11.254 255.255.255.255 Serial0/0/0 permanent
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
transport output none
scheduler allocate 20000 1000
end
Thanks for your help
royalblues
Level 10
Level 10
THe config looks ok to me.
Just check the T1 frame & linecode matches with that of the service provider.
check this link
http://www.cisco.com/en/US/products/hw/modules/ps2617/products_configuration_example09186a008052c920.shtml#Configure
Narayan
jhimye
In the controller config, unless you really want to use only timeslot 24, change it to
channel-group 0 timeslots 1-24
I've seen that mistake before.
Jhimye
