2911 with WICT2 card not accepting interface serial 0/2/0 command
Clay Plaga
Level 3
Level 3
I have a WICT2 card installed on a Cisco 2911 router. When I run show inventory
the router sees the card. When I try to configure the WICT2 card I receive this error:Router#config t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#interface serial 0/2/0
When I connect the serial cable into the WICT2 card, the card doesn't light up.
The carrot in under the s of serial. the router doesn't accept the command.How can I configure the WIC2T interface?
Thank you.
9 Replies 9
balaji.bandi
depends on where the card installed slot and module installed.
check below command syntax based on the card installed slot :
https://www.cisco.com/c/en/us/support/docs/routers/3600-series-multiservice-platforms/7261-wic-2t.html
still issue - post show modules to understand the issue
BB
The WICT2 card is installed EHWIC2. Also the router does not accept show modules command.
I think I need an HWIC-T2 card for the 2911. Thanks.
check the module support here  (2911 EOL Long back - you may get cheaper card in used seller may be)
https://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/data_sheet_c78_553896.html
correct syntax
show hw-module subslot [slot/ subslot] {brief | config | counters | errors | registers | status} device port
BB
Yes, I need the HWIC-T2 card for the 2911. The 2911 will be connected to a 1841. I can install a HWIC-T2 into the 1841. I found 2 HWIC-T2 on ebay for $45.00 each. I'll buy 2 cards and let's see what happens. Thanks everybody!
balaji.bandi
Nice good deal, keep us in loop how it goes ?
BB
Yes, I already ordered the HWIC-T2. This is for my test network. I'll keep you updated. Thanks!
In configuring these modules have you used the card type command?
Rick
No, I have not used the card type command. Show controllers serial 0/0/0 | include clock did work. Not on network now. Will check on Sunday.Thanks.
