2950 Trunk or not to Trunk ?
AJ69
Is it possible to trunk two 2950 switches? I can trunk one of the 2950 to a 3650 with no problem. When I try and trunk a 2950 with another 2950....That's a no go....
15 Replies 15
Prashanth Krishnappa
You sure can. Post your configs. All you need on the links connecting the 2 2950s is "switchport mode dynamic desirable" or "switchport mode trunk"
The config are listed below. The trunks are the same on both switches, but it just will not trunk between the two switches.
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 10.41.0.23 255.255.0.0
no shut
no ip route-cache
no ip domain-lookup
ip default-gateway 10.41.0.1
ip http server
Can you paste a "sh int gi 0/1 switchport" output ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
I can trunk to a 3650, but not to another 2950..
Output below..
GigabitEthernet0/2 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 0014.6a35.e572 (bia 0014.6a35.e572)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is RJ45
input flow-control is off, output flow-control is off
Last input never, output 17:07:50, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
m.lammerse
First thing that came to mind was that this could be a physical problem. For interconnecting 2 switches, you need a crosscable. Either that or you have faulty hardware. Did you try another port? The config looks ok to me.
Marcel
singh.ashish
Wat is the ios version of both 2950 switches?
Did u try to configure some other port?
regards...
Ashish singh
singh.ashish
yes it is possible to trunk Two 2950 switches. 2950 having some limitation like it only support 802.1q trunking and do not support ISL trunking.
regards...
Ashish Singh
The IOS IS 12.1 Used the "switchport mode trunk" command Also, tried swapping cables from a 3560 and 2950 trunk. Trunk came back up, but 2950 to 2950 trunk is still dead. I'm lost.... I read something about "EtherChannel"...?
What's your VTP configuration? Are the 2950's in the same domain with the same password? I believe you can use the 'show vtp domain' and 'show vtp status' to check.
HTH,
Marcel
AJ,
First check if the following things are proper.
1. A cross cable is used to interconnect the two switches - ethernet cross over or a fiber cable with Rx and Tx pins crossed so that you do see a link light on either ports of the 2950.
2. Configure Vlan 1 interface on both switches and configure them with an IP (which is typically) a management vlan.
switch 1
int vlan 1
no shut
ip add x.x.x.1 255.255.255.0
switch 2
int vlan 1
no shut
ip add x.x.x.2 255.255.255.0
3. The port that connects between the two switches are configured with Mode trunk (which you have already done)
int fa0/24
(Default trunking method is 802.1q, it doesnt support ISL)
4. Verify that Trunking is on using command...
show int fa0/24 switchport
5. Regarding VTP - If you run multiple vlans, its recommended to run VTP with one switch as VTP server and has the master database of vlans. All other switches are vtp client.
Switch 1
Switch#vlan database
Switch(vlan)#vtp server (or vtp mode server)
Switch(vlan)#vtp domain cisco.com
Switch(vlan)#vlan 2 name SERVER
Switch(vlan)#vlan 3 name PHONE
Switch(vlan)#vlan 4 name COMPUTERS
Switch(vlan)#exit
Switch 2
Switch(vlan)# vtp client (or vtp mode client)
Switch(vlan)#exit
The above configs should create vlan 2 and 3 on Switch 1 and configures it as a VTP server. Switch #2 will be VTP Client and if you do a Sh Vlan on Switch #2 you should see Vlan 2 and 3 in its database, if VTP is working correctly. This also means trunking is working properly across the two switches.
6. Configure two ports on each switch as part of vlan 2 (or 3) and ping between them.
Switch 1
int fa0/1
switchport mode access
switchport access vlan 2
Switch 2
int fa0/1
Sankar Nair
All this looks correct. Now here is the situation. All switches are being implemented are set for server. No VTP domain on any switch. It's kind of funny because I can trunk between two different model switches with none of the VTP configurations. There are no LED's lit on any of the switches ports where the crossover cable is connected. What gives?
VTP is not mandatory for trunking to work. It just simplifies the process of administering vlans (centralized administration rather than creating the same vlans on each switch)
You say you dont have link lights on the ports where the crossover cable is connected. This could be bad cable. Does the same crossover cable work between the 2950 and other switch (3750 or 3550) ? Or if this is a custom made cable, have you verified the pin outs, whether they are crimped correct ?
Sankar Nair
Did you finally solve this problem ?
Sankar Nair
Yes, I think there is some type of issue trying to trunk two gigabit interfaces between the 2950 switches. I just made fa0/48 a trunk to the Gi0/1 of the other switch. Problem solved.... Thanks for your input...
