3945 Ethernet Switch Module
Spagsterj
I have a Ethernet module (SM-ES3G-16-P) installed in a 3945 router and noticed during first boot no licenses are active at all. I would assume at a mimimum ipbase would be active.
With this module, does static routing work with just ipbase?
Example:
interface g0/1
no switchport
ip addr 192.168.254.2 255.255.255.0
int vlan 1
ip addr 172.16.1.2 255.255.255.252
ip route 0.0.0.0.0 0.0.0.0 172.16.1.1
switch#show license
Index 1 Feature: advipservices
        Period left: 0  minute  0  second
Index 2 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 3 Feature: ipbase
Thanks!
Yes it does. Static routing will work with ipbase.
Alessio
Is there a maximum of static routes?
I do not recall seeing any artificial limit on the count of static routes with IP Base on 3945 routers. I believe there is no practical limit.
Best regards,
Peter
Hello  Spagster
The configuration taht you post is all from de SM. also can you help me with the steps to do the initial configuration f the SM
