- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-25-2018 06:21 PM - edited 03-05-2019 10:56 AM
Can someone please clarify for me...
If I have a 4k router with a WAN connection on a routed port (100Mbps), and a switchcard in it with multiple LAN subnets terminating on SVIs. Does the inter-vlan traffic count towards the throughput license?
For example if you have a servers on one subnet and hosts on the other communicating at 1Gbps, will this exhaust the license on a 4331?
Solved! Go to Solution.
- Labels:
Other Routers
Other Routing
vEdge Routers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-26-2018 05:12 PM
Hi Jeff,
Per documentations, it does not use the platform performance license throughput.
Check 'Multigigabit Fabric' section. It clearly states "Throughput for direct module-to-module traffic using the MGF will thereby not be limited by the platform’s performance license levels."
Also Table.2 section "Intrachassis stacking or cascading" also provides some info on this.
hth
MS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-26-2018 05:12 PM
Hi Jeff,
hth
MS
