6509 High CPU
rajesh.kumar
Level 4
Level 4
We have two 6509 switch with IOS s72033-advipservicesk9_wan-mz.122-18.SXF9
Out of this two, one switch is showing high CPU utlization(more than 90%). Another switch shows 30-35% CPU utilization.
Both switch has same Hardware as well as software.
Pls. suggest what is causing one switch high CPU. How to bring this CPU utilization back to normal?
Here I have attached show proce cpu output.
Rgds
Rajesh Kumar
Peter Paluch
Rajesh,
I suggest reading the following documents for a good troubleshooting start:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00804916e0.shtml
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
You may also want to search these forums for additional information about 6500 CPU load, these issues have been discussed here quite often.
Best regards,
Peter
