01-06-2021 06:04 AM
Hello Team,
i need you kind assistance in solving the 7841 phones not registered with the CME, i am using 4331 router and 2960 Non POE switch. I can see the voice VLAN, TFTP server IP, and ping the phone but the phone still unregistered. i am working on this since several day with no luck
01-08-2021 01:05 AM
Hello Paul,
I will and let you know.
THANK YOU!!
khayri
01-09-2021 11:28 AM
Hello Paul,
I am able to ping the router, switch, TFTP server IP ( I am using the router as TFTP Server), and the phone but still the phone still unregistered, I have been work this for a long time with no luck.
Thank you for your help.
khayri
01-09-2021 11:40 AM
01-07-2021 03:09 AM
kindly so I need to connect the PC to the switchport that phone is connected and give the voice vlan IP
for example
interface vlan 10
ip address 192.168.1.5 255.255.255.0
then I will ping the switchport.
Thank you!
Khayri
01-07-2021 03:38 AM - edited 01-07-2021 03:40 AM
Hello
ping the CME server (via IP and FQDN ) from the pc that will be attached to the switchport assigned to the voice vlan, make sure you use the correct addressing (ip/subnet/default-gateway and dns)
01-09-2021 02:58 PM
looking at your config again, I think you might be missing the entire telephony-service section. It should look something like below:
telephony-service
no auto-reg-ephone
max-ephones 350
max-dn 4
ip source-address 192.168.1.10 port 2000
max-redirect 5
auto assign 4 to 6
auto assign 1 to 5
cnf-file location flash:
load 7841 sip78xx.11-5-1SR1-1.loads
load 7841 sip78xx.12-1-1SR1-4.loads
load 7841 sip78xx.12-5-1SR1-4.loads
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name Customer secret 5 $1$FMtR$sT3uVeM.oBYRlaOQSqvXj/
transfer-system full-consult
create cnf-files version-stamp 7841 Jan 09 2021 11:55:15
01-10-2021 06:18 AM
Hi George,
Thank you for your help, I m trying to figure out the CME SIP phones, I have downloaded the load files and I found that that I need the following files, would you please where can I download them:
- phone locale files
- Music On Hold
- Ringtones
Much Appreciated,
khayri
01-10-2021 07:26 AM
locale files can be downloaded from the link below, I believe.
https://software.cisco.com/download/home/277641082/type/282897001/release/12.5
01-12-2021 03:56 AM
Hi George,
I am able to download the file, I need one more favor regarding the trace logs, when I tried to run # sho flash to figure out where I extracted the cme file I found that have hundred of trace logs. i tried # clear logs but I still have the trace logs. below is short example
54803 Jan 04 2021 14:47:23.0000000000 +00:00 /bootflash/tracelogs/IOSRP_R0-0.17477_0.20210104142413.bin.gz
66 1509 Jan 12 2021 10:10:58.0000000000 +00:00 /bootflash/tracelogs/hman_pmanlog_0-0.30336_0.20210112075045.bin.gz
67 974 Jan 08 2021 18:51:13.0000000000 +00:00 /bootflash/tracelogs/install_engine_R0-0.3148_0.20210108185003.bin.gz
68 4326 Jan 06 2021 19:50:49.0000000000 +00:00 /bootflash/tracelogs/pvp_F0-0.23592_0.20210106171456.bin.gz
69 55935 Jan 12 2021 09:10:47.0000000000 +00:00 /bootflash/tracelogs/btman_F0-0.28913_0.20210112075043.bin.gz
70 56492 Jan 12 2021 09:10:29.0000000000 +00:00 /bootflash/tracelogs/btman_0-0.31986_0.20210112075047.bin.gz
71 4830 Jan 08 2021 14:58:52.0000000000 +00:00 /bootflash/tracelogs/iomd_0-0.985_0.20210108135303.bin.gz
72 1422 Jan 04 2021 16:16:58.0000000000 +00:00 /bootflash/tracelogs/cmand_pmanlog_R0-0.21734_0.20210104154258.bin.gz
73 2734 Jan 12 2021 10:15:01.0000000000 +00:00 /bootflash/tracelogs/cmcc_0-0.10821_0.20210112101406.bin.gz
74 57910 Jan 04 2021 18:39:40.0000000000 +00:00 /bootflash/tracelogs/btman_0-0.31869_0.20210104171959.bin.gz
75 62480 Jan 06 2021 19:08:41.0000000000 +00:00 /bootflash/tracelogs/sec_key_agent_R0-0.19804_1.20210106180641.bin.gz
76 72280 Jan 06 2021 18:06:41.0000000000 +00:00 /bootflash/tracelogs/sec_key_agent_R0-0.19804_0.20210106171451.bin.gz
77 56219 Jan 09 2021 18:32:05.0000000000 +00:00 /bootflash/tracelogs/btman_F0-0.28764_0.20210109171201.bin.gz
78 4887 Jan 12 2021 10:14:50.0000000000 +00:00 /bootflash/tracelogs/cmand_R0-0.10397_0.20210112101401.bin.gz
79 4382 Jan 09 2021 11:15:13.0000000000 +00:00 /bootflash/tracelogs/pvp_F0-0.23597_0.20210109103952.bin.gz
80 974 Jan 09 2021 17:11:55.0000000000 +00:00 /bootflash/tracelogs/install_engine_R0-0.3163_0.20210109171046.bin.gz
81 1883 Jan 08 2021 13:52:51.0000000000 +00:00 /bootflash/tracelogs/plogd_1-0.30522_0.20210108135249.bin.gz
01-12-2021 04:36 AM
you want to delete these logs from the bootflash ?
Device#delete bootflash: file_name
01-10-2021 08:19 AM
Thank you!!
