871 high CPU utilization
catalin.stan
I have a 871 and when I'm downloading a bigger file (over 100 MB) or uploading via FTP the CPU goes to 99%.
I have tested this with basic configuration (only nat and dhcp service configured). I have install the latest IOS version that is supported on the router (c870-advipservicesk9-mz.124-24.T8.bin) but I still have the same problem.
Can someone please let me know if this is a normal behavior for 871. Will a flash/RAM upgrade will help?
Thank you
35 Replies 35
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The sum of all your interface rates, either all ingress rates or all egress rates (don't count both at the same time).
paolo bevilacqua
Seems to me you want to use the router for inter-vlan router.
As other have indicated, It does not have enough performances to do that, no matter how much RAM you stuff in it.
You need a L3 switch for inter-vlan routing.
I'm don't want to use this router as inter-vlan switching.
I just need it for gateway/nat/dhcp.
I've reconfigured the interfaces so I only have the native vlan. I have the same problem with this configuration.
It's very strange that a transfer for a file less then 100M works fine and for 200M + the CPU goes to 98%.
test#sh run
Building configuration...
Current configuration : 1244 bytes
version 12.4
no service pad
hostname test
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.200.1 192.168.200.10
ip dhcp pool LAN192
   network 192.168.200.0 255.255.255.0
   default-router 192.168.200.1
   dns-server 8.8.8.8
ip cef
no ipv6 cef
archive
log config
  hidekeys
ip ssh version 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description outside
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
ip address 192.168.200.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT_ACL interface FastEthernet4 overload
ip access-list extended NAT_ACL
permit ip 192.168.200.0 0.0.0.255 any
What is the speed of your internet service ?
5 Mbs
Sorry, I don't know the reason.
I would update IOS again, that requires a dram and memory upgrade too.
