VWIC3-2MFT-T1/E1 Active Serial
iec1128759
I have a problem I can not activate the command
e1 card-type 0 0
And I can not activate the Serial, and try in various slots of the router but does not work
The Router this command does not allow me
The IOS version flash0: C2900-universalk9-mz.SPA.151-4.M5.bin
Router model is CISCO2921/K9
  And I have 3 licenses activated
Technology Technology-package Technology-package
               Current Type Next reboot
Permanent ipbasek9       ipbase     ipbasek9
Permanent securityk9     security   securityk9
uc             None             None       None
Permanent datak9           data        datak9
The card is VWIC3-2MFT-T1/E1 model - 2-Port RJ-48 Multiflex Trunk - T1/E1
I hope someone can help me
Greetings.
5 Replies 5
paolo bevilacqua
post show diag.
Router# sh diag
Slot 0:
        C2921 Mother board 3GE, integrated VPN and 4W Port adapter, 7 ports
        Port adapter is analyzed
        Port adapter insertion time 14:41:05 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC17163UJ8
        Hardware Revision        : 1.0
        Part Number              : 73-11835-11
        Top Assy. Part Number    : 800-30794-07
        Board Revision           : A0
        Deviation Number         : 130603
        Fab Version              : 03
        Product (FRU) Number     : CISCO2921/K9
        Version Identifier       : V08
        CLEI Code                : CMMHS10ARB
        Processor type           : C2
        Chassis Serial Number    : FTX1722AHMA
        Chassis MAC Address      : 6c41.6a1d.1690
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 37 31 36 33 55 4A 38 40
          0x10: 06 16 41 01 00 82 49 2E 3B 0B C0 46 03 20 00 78
          0x20: 4A 07 42 41 30 88 00 01 FE 2B 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 32 31 2F 4B 39 89 56 30 38 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 48 53 31 30 41 52
          0x50: 42 09 C2 C2 8B 46 54 58 31 37 32 32 41 48 4D 41
          0x60: C3 06 6C 41 6A 1D 16 90 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0226-03
        Deviation Number         : 0
        PCB Serial Number        : QCS1707H2N8
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V03
        Product (FRU) Number     : PWR-2921-51-AC
        CLEI Code                : 0000000000
        Board Revision           : A0
          0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 03 88 00 00 00
          0x10: 00 C1 8B 51 43 53 31 37 30 37 48 32 4E 38 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 33 20 CB 8E 50 57
          0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
          0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
          0x50: 05 F8 00 50 01 F4 14 41 02 EE 16 F0 03 E8 18 C9
          0x60: 04 E2 1A 76 05 DC 1B 91 06 D6 1C 78 07 D0 1D 10
          0x70: 08 CA 1D 9E 09 C4 1E 6D 0A BE 1E A8 0B B8 1F 5E
          0x80: 0D AC 20 FB 0F A0 21 18 11 94 21 64 13 88 21 71
          0x90: 17 70 21 9F 1B 58 21 96 1F 40 21 6D 23 28 21 62
          0xA0: 27 10 21 5A 42 41 30 FF FF FF FF FF FF FF FF FF
        WIC Slot 2:
        VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
        Top Assy. Part Number    : 800-34658-01
        Part Number              : 73-13420-01
        Board Revision           : B0
        Fab Version              : 05
        PCB Serial Number        : FOC17186110
        Version Identifier       : V01
        Product (FRU) Number     : VWIC3-2MFT-T1/E1
        CLEI Code                : COUIA7NCAA
        RMA History              : 00
          0x00: 04 FF 40 06 EF 41 01 00 C0 46 03 20 00 87 62 01
          0x10: 82 49 34 6C 01 42 42 30 88 00 00 00 00 02 05 C1
          0x20: 8B 46 4F 43 31 37 31 38 36 31 31 30 89 56 30 31
          0x30: 20 CB 90 56 57 49 43 33 2D 32 4D 46 54 2D 54 31
          0x40: 2F 45 31 C6 8A 43 4F 55 49 41 37 4E 43 41 41 03
          0x50: 00 81 00 00 00 00 04 00 D9 03 40 C1 CB FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 3:
        Board Revision           : B0
        Fab Version              : 05
        PCB Serial Number        : FOC171861KJ
        RMA History              : 00
          0x20: 8B 46 4F 43 31 37 31 38 36 31 4B 4A 89 56 30 31
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
command is
card type e1 x 0
When I test this command, the router does not accept
Router(config)#card type E1 x 0
% Invalid input detected at '^' marker.
Router(config)#card type E1 0 2
Even if it should not be required, try activating the UC evaluation license.
