871 interface config question
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-25-2009 04:01 PM - edited 03-04-2019 04:52 AM
Hello
I currently have a Cisco 871 router. When I configure the WAN interface with no ip route-cache the router adds no ip route-cache cef in automatically??
Does anyone know why? Below is the output:
With ip route-cache & ip route-cache cef
router1#sh run int f4
Building configuration...
Current configuration : 113 bytes
interface FastEthernet4
ip address 95.95.95.3 255.255.255.0
no ip mroute-cache
duplex auto
speed auto
end
router1#
Then disable ip route-cache
router1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
router1(config)#int f4
router1(config-if)#no ip rou
router1(config-if)#no ip route-cache
router1(config-if)#^Z
Current configuration : 155 bytes
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
end
As can be seen above the cef is included. Yet when checking my router config it shows I have cef enabled on the router.
router1#sh run | i cef
ip cef
Can someone please explain what I am missing?
willemvw
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-26-2009 06:41 AM
Hi Willemvw,
From the output of your sho run above I can see you used 'no ip route-cache cef'.
If your interest is to disable ip cef, use 'no ip cef'.
How ever when you disable ip cef, 'ip verify unicast reverse-path' is also removed (if configured).
I think this feature or behavior has to do with the ios version.
Cheers.
Tom
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-26-2009 01:06 PM
Hi Tom
Can you please point out where I used 'no ip route-cache cef'?
To my knowledge I need to type in 'no ip route-cache cef' in order to disable it, yet I have not typed that in.
Thanks for your help :)
regards
willemvw
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-26-2009 11:24 AM
Why do do want to disable ip route-cache (that is not the default anymore since years) anyway ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-26-2009 12:59 PM
Hi Paolo
Thanks for the reply. When did this stop becoming the default?
I am disabling ip route-cache purely from a configuration point of view. I am setting up 2 routers to use ezvpn and the config I am using requires no ip route-cache.
I will be posting some ezvpn questions later on the forum
willemvw
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-26-2009 01:18 PM
I think CEF became default about 8 years ago.
Please post a reference about what makes you believe you need to disable route-cache for EzVPN.
