878 configuration
juandelacruz17
hello there, i am a newbie with cisco routers. i was able to connect to 2 buildings using 1600 on the one end and a 1700 series router on the other end thru a copper lease line. i just found a cisco 878 router in the market and it has a g.shdsl wan port, can i use it on both ends? what would be the requirements? is the copper lease line enough? thank you so much in advance.
juandelacruz
11 Replies 11
paolo bevilacqua
Sure, copper dry pair lease will let you connect the two g.shdsl routers just fine. Remember one side has to provide clock.
Hope this helps, if so please rate post!
p.bevilacqua, thank you very much for your immediate reply would you mind if you have a basic config on this.. i'm very sorry to post this i am really confuse.
thank you
Nothing to be sorry. Look at this doc for configuration;
http://cisco.com/en/US/tech/tk175/tk274/technologies_configuration_example09186a0080135834.shtml
Hope this helps, if so please rate post using the scrollbox below!
sir, this doc really helps me a lot. straight forward config. thank you so much. i have just wandering one thing on my setup from computer at building two i can ping the ip of the ethernet and atm of the two routers also the LAN at building b.... but from a computer from building b, i cannot ping the ip of the atm0, but I can see the LAN. I think it's weird. What would be the thing that i miss in the configuration.? here is the config. thanks
ip dhcp excluded-address xxxxxxx
no ip domain lookup
ip name-server xxxxxxx
controller DSL 0
mode atm
line-term co
line-mode 2-wire line-zero
dsl-mode shdsl symmetric annex A
line-rate 2304
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
encapsulation aal5snap
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description Local Area Connection
ip address xxxxxxxxxxxxxxxx
ip tcp adjust-mss 1452
interface Dialer0
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ip classless
ip route xxxxxxxxxxxxxx
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit xxxxxxxx
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password xxxxxxx
login
transport input telnet ssh
scheduler max-task-time 5000
end
do you feel ready for a little bit of dynamic routing?
on both routers:
router rip
version 2
network
redistribute static
At that point if you do "show ip route" on the other building router you should see "0.0.0.0 via ". Configure the PC to router as default gateway and you are fine.
Sir,
good day, just a question, once that this has been issued do I have to delete the static route. this seems to be an idiot question, but i am confuse. thank you very much
When dynamic routing is in place,you just need to leave the static default route 0.0.0.0.
There is also a setting so that it is learnt automatically from PPP, but it not so important to do so.
guys, i was able to have the existing configuration work, problem is i forgot to make a static route to the internal LAN. it is now working. with regards to the dynamic routing, i've tried it on my other setup and it works fine. thank you so much for being patience with me.
guys, it's me again just wanted to know as what are the things that i needed for voip setup. does 878 can be use for voip. thank you again so much.
Sure can do Voip, connect you equipment and if there are quality issues search CCO "LLQ QoS" and try to apply a configuration example.
You got this working I see and I'm trying to do exactly the same thing. Could you possibly post a working config of both the CO & CPE routers please ?
Stuart
