Multiple ISP connecting to one router
chenoi2007
Hai, need ur profesional advised,
i have 1 core router that connected to 3 ISP and 5 customer with differ capacity
cust1-ISP1-2M
cust2-ISP1-4M
cust3-ISP2-stm1
cust4-ISP3-45M
cust5-ISP3-8M
1. do i need edge router that will interconnect to my customer. can i directly connect to my core router?
2. all routing to ISP is static route. ist possible
3.how can i manage the bandwith as different customer and different isp. is there a way i can have this via policy.
4. do i need to dedicate one customer to one router port, is there a way i can shared everything and save my port expecially E1 port which is expensive?
I really need your answer and help.. iam alone..i already try searching but nothing close.
please my frenz. TQ in advanced!
9 Replies 9
bvsnarayana03
Level 5
Level 5
1. Either u get a separate edge router or WIC ports for each customer.
2. Use separate VRF instances for each customer. This way u can manage with static routes.
3. U can police the bandwidth on each interface to restrict it to the required value.
1. Either u get a separate edge router or WIC ports for each customer. --> can i have multiple customer with different bandwith req and prefered isp into one edge router.
2. Use separate VRF instances for each customer. This way u can manage with static routes. --> even if my network is not MPLS i can run VRF?
3. U can police the bandwidth on each interface to restrict it to the required value.--> this interface referring to edge router interface? or core router interface?
TQ
advised please,
if i only have one core router is it possible to have MPLS running? and do i must have PE router?
one more thing.. is this design possible?
any comment my frenz
Looking at your original requirement one core router will do, you can directly connect your customers, no mpls or vrf lite required.
Just use PBR and policing.
Please note I thumb sucked most of the values and you should LAB test this first.
Keep in mind NAT might also be a requirement, depending on your addressing scheme.
Depending on your router hardware the config should look something like this:
#CUST1 ip range
access-list 1 permit 192.168.1.0 0.0.0.255
#CUST2 ip range
access-list 2 permit 192.168.2.0 0.0.0.255
#CUST3 ip range
access-list 3 permit 192.168.3.0 0.0.0.255
#CUST4 ip range
access-list 4 permit 192.168.4.0 0.0.0.255
#CUST5 ip range
access-list 5 permit 192.168.5.0 0.0.0.255
class map CUST1
match access-group 1
class map CUST2
match access-group 2
class map CUST2
match access-group 3
class map CUST3
class map CUST4
match access-group 4
class map CUST5
match access-group 5
route-map ISP1 permit 10
match ip address 1
set interface ATM1/0
route-map ISP1 permit 20
match ip address 2
route-map ISP2 permit 10
match ip address 3
set interface POS2/0
route-map ISP3 permit 10
match ip address 4
set interface ATM1/1
route-map ISP3 permit 20
match ip address 5
policy-map ISP1
class CUST1
bandwidth 2048
police 2048000 20000 40000 conform-action transmit exceed-action drop
class CUST2
bandwidth 4096
police 4096000 40000 80000 conform-action transmit exceed-action drop
policy-map ISP3
class CUST4
bandwidth 45056
police 45056000 450000 900000 conform-action transmit exceed-action drop
class CUST5
bandwidth 8192
police 8192000 80000 160000 conform-action transmit exceed-action drop
interface ethernet 0/1
description CUST1
ip policy route-map ISP1
interface ethernet 0/2
description CUST2
interface ethernet 0/3
description CUST3
ip policy route-map ISP2
interface ethernet 0/4
description CUST4
ip policy route-map ISP3
interface ethernet 0/5
description CUST5
interface ATM1/0
description ISP1
service-policy output ISP1
interface ATM1/1
description ISP3
service-policy output ISP3
interface POS2/0
description ISP2
Phillip
Hai..thanks phillip,
my network design ok? and i can connect directly to my core. no need mpls and vrf.
fyi..i didnt have control on the ip address , it will given by upstream provider to our customer. we only handle the routing from our customer to their respective isp. so..is this configuration suitable also with my scenario?... TQ
any comment and idea... i will consider it TQ
Sorry, been out of the office.
Yes the configuration is suitable with your scenario, you just need to mark cust IP addresses provided by the ISP with the ACL.
As for bringing it in to your core, it will work but not best practise, this all depends on the requirements and feasibility of adding a dedicated edge box. Either way no mpls or vrf required.
Phillip
hai Phillip...thanks..very useful..thanks..cheeerss
