access-list remarks
Hi all,
I have another question here.
I want to add remarks in an existing ACL. Can i do that without rewriting the entire access-list or do i have to remove it and create it again?
For instance I have this ACL
ip access-list extended NAT
deny   ip host 192.168.5.6 10.100.100.0 0.0.0.255
deny   ip host 192.168.5.7 any
permit ip any any
And i want to add the following lines:
remark deny SMTP server from being NATed
remark deny web server from being NATed
remark NAT everything else
  permit ip any any
Can i do that without any downtime? I have done it in ASA but when i try Cisco Configuration professional, the preview commands are
no ip access-list extended NAT
  permit ip any any
In which i want to avoid because it would cause downtime.
TIA, Nicos Nicolaides
  I just tried with Cisco Configuration Professional.
I had the following config:
interface g0/1
ip addr 10.104.58.183 255.255.255.0
ip access-group test in
ip access-list extended test
deny   ip host 10.104.58.164 any
permit ip any any
I am trying to ping 10.104.58.183 from host 10.104.58.164. (The ping works fine when there is no ACL test on intergace g0/0)
I discover the device through Cisco CP and edit the ACL test to configure the remark.
This is what is shown in the CLI preview:
no ip access-list extended test
remark testing ACL
remark CCP_ACL Category=17
permit ip any any
exit
I did not see any downtime. I would have expoected ping from 10.104.58.164 to succeed while delivering the CLI but actually it didn't.
6 Replies 6
Edison Ortiz
First, execute show ip access-list from the exec mode and note the line numbering on the access-list entries.
Second, enter in config mode and go into the access-list submode by typing ip access-list extended NAT
Third, when entering the command select a number that's between the line numbering from step 1. For instance:
10 deny   ip host 192.168.5.6 10.100.100.0 0.0.0.255
20 deny   ip host 192.168.5.7 any
30 permit ip any any
You would enter
5 remark deny SMTP server from being NATed
15 remark deny web server from being NATed
25 remark NAT everything else
Edison
Thank you for your reply Edison ,
I have tried this but it does not work. Here is the output of the router.
LOGBG>sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 23-Mar-10 06:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
LOGBG uptime is 1 week, 4 days, 19 hours, 30 minutes
System returned to ROM by bus error at PC 0x4177FC80, address 0x931B at 14:19:32 EEST Tue Sep 7 2010
System restarted at 14:21:29 EEST Tue Sep 7 2010
System image file is "flash:c2800nm-advsecurityk9-mz.124-24.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FCZ101470JQ
7 FastEthernet interfaces
1 Serial(sync/async) interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
LOGBG>
LOGBG>en
Password:
LOGBG#sh ip ac
LOGBG#sh ip acce
LOGBG#sh ip access-lists NAT
Extended IP access list NAT
    20 deny ip host 192.168.5.7 any (7867 matches)
    30 permit ip host 192.168.5.6 any (409 matches)
    40 permit ip host 192.168.7.9 any (11101 matches)
    50 deny ip 192.168.0.0 0.0.0.255 10.2.0.0 0.0.255.255
    60 deny ip 192.168.1.0 0.0.0.255 10.2.0.0 0.0.255.255
    70 deny ip 10.0.0.0 0.0.0.255 10.2.0.0 0.0.255.255 (1745 matches)
    80 deny ip 192.168.0.0 0.0.0.255 10.4.1.0 0.0.0.255
    90 deny ip 192.168.1.0 0.0.0.255 10.4.1.0 0.0.0.255
    100 deny ip 10.0.0.0 0.0.0.255 10.4.1.0 0.0.0.255
    110 deny ip 192.168.0.0 0.0.0.255 10.11.1.0 0.0.0.255
    120 deny ip 10.5.1.0 0.0.0.255 10.11.1.0 0.0.0.255
    130 deny ip 192.168.0.0 0.0.0.255 10.12.1.0 0.0.0.255
    140 deny ip 10.5.1.0 0.0.0.255 10.12.1.0 0.0.0.255
    150 deny ip 192.168.0.0 0.0.0.255 10.6.1.0 0.0.0.255
    160 deny ip 192.168.1.0 0.0.0.255 10.6.1.0 0.0.0.255
    170 deny ip 10.0.0.0 0.0.0.255 10.6.1.0 0.0.0.255
    180 deny ip 10.5.1.0 0.0.0.255 10.6.1.0 0.0.0.255
    190 deny ip 192.168.0.0 0.0.1.255 10.1.0.0 0.0.255.255 (10 matches)
    200 deny ip 10.0.0.0 0.0.0.255 10.1.0.0 0.0.255.255
    210 deny ip 10.5.1.0 0.0.0.255 10.1.0.0 0.0.255.255
    220 deny ip 192.168.0.0 0.0.0.255 10.10.11.0 0.0.0.255
    230 deny ip 192.168.0.0 0.0.0.255 172.16.0.0 0.0.255.255 (10515 matches)
    240 deny ip 10.0.0.0 0.0.0.255 172.16.0.0 0.0.255.255 (1882 matches)
    250 deny ip 192.168.9.0 0.0.0.255 10.6.1.0 0.0.0.255
    260 deny ip 192.168.0.0 0.0.0.255 10.8.1.0 0.0.0.255
    270 deny ip 10.0.0.0 0.0.0.255 10.8.1.0 0.0.0.255
    280 deny ip 192.168.0.0 0.0.1.255 10.9.1.0 0.0.0.255 (6 matches)
    290 deny ip 10.0.0.0 0.0.0.255 10.9.1.0 0.0.0.255
    300 deny ip 10.0.0.0 0.0.0.255 10.9.2.0 0.0.0.255
    310 deny ip 192.168.0.0 0.0.0.255 10.3.1.0 0.0.0.255
    320 deny ip 10.0.0.0 0.0.0.255 10.3.1.0 0.0.0.255
    330 deny ip host 192.168.5.6 any
    340 permit ip 192.168.0.0 0.0.0.255 any (299103 matches)
    350 permit ip 192.168.2.0 0.0.0.255 any (13032 matches)
    360 permit ip 192.168.5.0 0.0.0.255 any (1128894 matches)
    370 permit ip 10.0.0.0 0.0.0.255 any (108396 matches)
    380 permit ip 192.168.8.0 0.0.0.255 any
    390 permit ip 192.168.7.0 0.0.0.255 any (2694 matches)
    400 permit ip 192.168.9.0 0.0.0.255 any (73 matches)
    410 permit ip 192.168.4.0 0.0.0.255 any (1205 matches)
    420 permit ip 10.5.1.0 0.0.0.255 any (113377 matches)
    430 permit ip 192.168.19.0 0.0.0.255 any
    440 permit ip host 192.168.5.2 any
    450 permit ip 192.168.124.0 0.0.0.255 any (19377 matches)
    460 deny ip any any (2775174 matches)
LOGBG#sh run | i NAT
ip nat inside source list NAT interface FastEthernet0/1 overload
ip nat inside source list NAT2 interface FastEthernet0/0 overload
ip access-list extended NAT2
LOGBG#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
LOGBG(config)#ip access-list extended NAT
LOGBG(config-ext-nacl)#5 remark do not NAT GPS server when going to network 10.100.100.0/24
% Invalid input detected at '^' marker.
LOGBG(config-ext-nacl)#5 ?
  deny      Specify packets to reject
  dynamic   Specify a DYNAMIC list of PERMITs or DENYs
  evaluate  Evaluate an access list
  exit      Exit from access-list configuration mode
  permit    Specify packets to forward
do you think i may have hit a bug?
    For editing the ACL on the Router, I guess you will have to remove the ACL and reconfiugre it. I tried adding the Remarks after creating the extended ACL. Even though the CLI did not throw an error, the Remarks CLI was not accepted and it did not appear in the running config.
And when you issue a "no access-list" and configure it back, there will be a downtime
Chaitra
interface g0/1
permit ip any any
remark testing ACL
permit ip any any
exit
If using the CLI consider installing a new ACL; this wont result in downtime.
Let's say your current ACL is 100 and the config looks something like this:
access-list 100 deny ip any 172.16.0.0 0.0.0.255
access-list 100 permit ip any any
int fa0/0
ip access-group 100 in
exit
Now we want to add a remark or additional rule; use another ACL.
access-list 101 remark *** FA0/0 Ingress ***
access-list 101 remark *** 20101001 ***
access-list 101 deny ip any 192.168.0.0 0.0.255.255
access-list 101 deny ip any 172.16.0.0 0.0.0.255
access-list 101 permit ip any any
int fa0/0
ip access-group 101 in
exit
This results in no downtime and gives you an opportunity to backout the change quickly if things don't work as anticipated.  30 days latter get rid of the old ACL.
Chris
But of course! You are right. Replacing an access-list with an other in an interface cause no downtime. So this is the solution!
Thank you for your support and your time,
Nicos
