Access tftp-server service from a PC
bellaichef
Hi is there any way to access a router tftp-server from a pc tftp client.
This is what I've done:
On the router
tftp-server flash:config.txt
On the pc (linux):
tftp
connect "public ip"
get config.txt
If I check my ACLs, I can see that request from my PC are authorized, but i always get a timeout.
If I try from another Cisco equipment with the following commad it works:
copy tftp: flash:
"public ip"
config.cfg
it works.
So it there a way to make it works from a PC?
Thx bye advance.
Franck
Aaron Harrison
Can you post your ACLs?
Also try disabling windows firewall or other firewalls on the client PC.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Not sure it will be useful.
the start of the ACL on the outside interface:
Extended IP access list Outside_In
    10 permit icmp any any (557664 matches)
    20 permit ip host "my public ip" any (60 matches)
The client PC is a Linux, no firewall.
The matchs you see in the ACL are all attempts from my pc to the router.
Cheers.
Franck
