08-13-2020 06:28 AM
Configuring OSPF neighborship between ACI and Catalyst 4507 switch but the neighbors are stuck in Exchange/DR.
The MTU on ACI is 9000 by default and on Cat4k is 1500. I did configure 'mtu-ignore' on both sides and still unable to bring the neighbor up. Will I have to hard code the MTU on ACI L3Out interface to make this work?
Solved! Go to Solution.
08-13-2020 07:16 PM
removed the ' ip ospf mtu-ignore' on both sides and hardcoded the mtu size on Cat4k switch interface to 9000 and the neighbor state changed to Full
The mtu-ignore probably didn't work due to some bug.
08-13-2020 07:10 AM - edited 08-13-2020 07:11 AM
Hello
Is it an mtu mismatch causing this issue?
Can you ping the neighbour with increasing mtu sizes?,
What does the debug state?
Debug ip ospf adj
08-13-2020 07:10 AM
if you already configured MTU ignor still having issue.
Steps :
1. shutdown both the side interface and bring up see if that work
2. if not enable debug one of the side and check what is the errors ? below guide help you.
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/13684-12.html
08-13-2020 07:16 PM
