Activating my purchased throughput license on Cisco 4331
mhdganji110
I purchased a license for my4331 router. bandwidth feature, got the lic file and installed it on router successfully
I changed the throughput to 300000 and restarted router and now it is working but the weird thing is that I still see the feature as evaluation and an expiring time. Am I missing any other command here?
Or transition means that after eval it will be activated permanently and I should not worry
show license detail throughput
Feature: throughput                      Period left: 8  weeks 3  days
Index: 1        Feature: throughput                        Version: 1.0
        License Type: EvalRightToUse
        License State: Active, In Use
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 3  days
            Period used: 24 minutes 38 seconds
            Transition date: Dec 31 2018 17:06:08
        License Count: Non-Counted
        License Priority: Low
        Store Index: 6
        Store Name: Built-In License Storage
mesehar
It remains an EvalRTU license for 60 days and then it changes automatically to Right-To-Use License.The behavior you are seeing is expected,
mesehar
Deepak Kumar
If you installed successfully than it will auto changed after 8 weeks.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Slabre
You have the possibility to directly move to Permanent mode instead of wait for the 60 days :
#license right-to-use move throughput
If you are not invited to accept end user agreement, either you already accepted it or you can do it with :
(config)#license accept end user agreement
No need to reload if you already changed the throughput (for which a reload is mandatory to take effect). For those who ask, you can change the throughput with this command :
(config)#platform hardware throughput level <value in kbps>
Hope this helps.
