DMVPN & Site-to-site VPN on same router, S2S not working DMVPN is working
Michael Durham
Level 4
Level 4
There is NO ASA in this config.
I have a network with the HQ router being a 3925 on IOS 15.7 and it has a DMVPN configured and working to connect to my customers on an as needed bases.  I want to set up a remote worker for my company and they have a 1921 running IOS 15.7.  I am trying to use a site-to-site VPN for this.  We will also be setting up site-to-site VPN’s for some of our customers for their employees to work remotely including VoIP phones.
First question, can a DMVPN and a site-to-site VPN exist on the same router?
Our customers will rarely be connected to our DMVPN as it is only for us to support their VoIP system.  ALL routers will be Cisco 2900 or 3900 series.  I would hate to make them drop any site-to-site connections to their employees while we needed to make a change to their CME config.  WE WILL NOT have access to their networks or their remote users in any way and we don’t want any.
Below are my configs for both our HQ router and our HOME employee router and some test results.
We have the DMVPN working perfectly!  Connection to a test customer is working.
We cannot get communication between the HQ and the HOME router.
It looks like the HQ router show crypto map does not show the 192.168.50.0 network but it is in the config.
Both HQ and Home routers can ping the internet 4.2.2.2
What am I missing to get this working?
One it is working, is the site-to-site VPN encrypted?  It does not look like it is but the DMVP does
HQ ROUTER
crypto isakmp policy 100
 encr aes 256
 hash sha512
 authentication pre-share
 group 16
 lifetime 3600
crypto isakmp key abc123def address 0.0.0.0
crypto isakmp keepalive 10 periodic
crypto dynamic-map DYNAMIC_CORP_VPN 10
 set security-association lifetime seconds 86400
 set transform-set PSE_SUPPORT-TSET
 match address ACL_VPN_CORP_TO_BRANCH
crypto map CONVERTED_DYNAMIC-MAP_TO_STATIC-MAP 1 ipsec-isakmp dynamic DYNAMIC_CORP_VPN
crypto ipsec transform-set PSE_SUPPORT-TSET esp-aes esp-sha512-hmac
 mode tunnel
crypto ipsec profile PSE_SUPPORT-IPSEC
interface GigabitEthernet0/0.110
 ip address 10.110.0.1 255.255.255.0
interface GigabitEthernet0/0.50
ip address 192.168.50.1 255.255.255.0
interface GigabitEthernet0/0.69
ip address 192.168.69.1 255.255.255.0
interface GigabitEthernet0/0.169
ip address 192.168.169.1 255.255.255.0
interface GigabitEthernet0/2
 ip address 1.4.2.8 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 no ip route-cache
 duplex auto
 speed auto
ip nat inside source list 151 interface GigabitEthernet0/2 overload
ip route 0.0.0.0 0.0.0.0 1.4.2.7
ip access-list extended ACL_VPN_CORP_TO_BRANCH
 permit ip 192.168.50.0 0.0.0.255 172.31.0.0 0.0.0.7
 permit ip 192.168.69.0 0.0.0.255 172.31.0.0 0.0.0.7
 permit ip 10.110.0.0 0.0.0.255 172.31.0.0 0.0.0.7
 deny   ip any any
access-list 151 permit ip 10.0.0.0 0.255.255.255 any
access-list 151 permit ip 172.16.0.0 0.15.255.255 any
access-list 151 permit ip 192.168.0.0 0.0.255.255 any
HOME ROUTER
ip dhcp excluded-address 172.31.0.1 172.31.0.4
ip dhcp pool Remote_Users
 network 172.31.0.0 255.255.255.248
 default-router 172.31.0.1
 option 150 ip 10.110.0.1
 dns-server 172.31.0.1
 domain-name thedurhamcorporation.com
 lease 0 12
 encr aes 256
 hash sha512
 group 16
 lifetime 3600
crypto isakmp key 6 abc123def address 1.4.2.8
 mode tunnel
crypto map BRANCH_TO_CORP_VPN 10 ipsec-isakmp
 set peer 1.4.2.8
 match address ACL_VPN_BRANCH_TO_CORP
 description Internet Access Port
 ip address 2.1.1.3 255.255.255.224
 ip nat outside
 no ip route-cache
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 172.31.0.1 255.255.255.248
 ip nat inside
 duplex auto
 speed auto
ip nat inside source list 151 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 2.1.1.1
ip access-list extended ACL_VPN_BRANCH_TO_CORP
 permit ip 172.31.0.0 0.0.0.7 192.168.50.0 0.0.0.255
 permit ip 172.31.0.0 0.0.0.7 192.168.69.0 0.0.0.255
 permit ip 172.31.0.0 0.0.0.7 10.110.0.0 0.0.0.255
 deny   ip any any
access-list 151 remark Block NAT Service to VPN
access-list 151 deny   ip 172.31.0.0 0.0.0.7 192.168.50.0 0.0.0.255
access-list 151 deny   ip 172.31.0.0 0.0.0.7 192.168.69.0 0.0.0.255
access-list 151 deny   ip 172.31.0.0 0.0.0.7 10.110.0.0 0.0.0.255
access-list 151 permit ip 172.31.0.0 0.0.0.7 any
HQ ROUTER
show crypto isakmp policy
Global IKE policy
Protection suite of priority 100
        encryption algorithm:   AES - Advanced Encryption Standard (256 bit keys).
        hash algorithm:         Secure Hash Standard 2 (512 bit)
        authentication method:  Pre-Shared Key
        Diffie-Hellman group:   #16 (4096 bit)
        lifetime:               3600 seconds, no volume limit
HOME ROUTER
Global IKE policy
HQ ROUTER
Transform set default: { esp-aes esp-sha-hmac  }
   will negotiate = { Transport,  },
Transform set PSE_SUPPORT-TSET: { esp-aes esp-sha512-hmac  }
   will negotiate = { Tunnel,  },
HOME ROUTER
HQ ROUTER * Network 192.168.50.0 is missing below
show crypto map
Crypto Map IPv4 "CONVERTED_DYNAMIC-MAP_TO_STATIC-MAP" 1 ipsec-isakmp
        Dynamic map template tag: DYNAMIC_CORP_VPN
Crypto Map IPv4 "CONVERTED_DYNAMIC-MAP_TO_STATIC-MAP" 65536 ipsec-isakmp
        Peer = 2.1.1.3
        Extended IP access list
            access-list  permit ip 10.110.0.0 0.0.0.255 172.31.0.0 0.0.0.7
        Current peer: 2.1.1.3
            dynamic (created from dynamic map DYNAMIC_CORP_VPN/10)
        Security association lifetime: 4608000 kilobytes/86400 seconds
        Responder-Only (Y/N): N
        PFS (Y/N): N
        Mixed-mode : Disabled
        Transform sets={
                PSE_SUPPORT-TSET:  { esp-aes esp-sha512-hmac  } ,
Crypto Map IPv4 "CONVERTED_DYNAMIC-MAP_TO_STATIC-MAP" 65537 ipsec-isakmp
        Peer = 2.1.1.3
            access-list  permit ip 192.168.69.0 0.0.0.255 172.31.0.0 0.0.0.7
        PFS (Y/N): N
        Transform sets={
Crypto Map IPv4 "CONVERTED_DYNAMIC-MAP_TO_STATIC-MAP" 65538 ipsec-isakmp
        Peer = 2.1.1.3
            access-list  permit ip 192.168.50.0 0.0.0.255 172.31.0.0 0.0.0.7
        PFS (Y/N): N
        Transform sets={
        Interfaces using crypto map CONVERTED_DYNAMIC-MAP_TO_STATIC-MAP:
                GigabitEthernet0/2
        Interfaces using crypto map NiStTeSt1:
Crypto Map IPv4 "Tunnel0-head-0" 65536 ipsec-isakmp  *DMVPN Tunnel
        Profile name: PSE_SUPPORT-IPSEC
        PFS (Y/N): N
        Transform sets={
Crypto Map IPv4 "Tunnel0-head-0" 65537 ipsec-isakmp
        Map is a PROFILE INSTANCE.
        Peer = 192.168.69.252
            access-list  permit gre host 1.4.2.8 host 192.168.69.252
        Current peer: 192.168.69.252
        PFS (Y/N): N
        Transform sets={
        Interfaces using crypto map Tunnel0-head-0:
                Tunnel0
HOME ROUTER
show crypto map
Crypto Map IPv4 "BRANCH_TO_CORP_VPN" 10 ipsec-isakmp
        Peer = 1.4.2.8
        Extended IP access list ACL_VPN_BRANCH_TO_CORP
            access-list ACL_VPN_BRANCH_TO_CORP permit ip 172.31.0.0 0.0.0.7 192.168.50.0 0.0.0.255
            access-list ACL_VPN_BRANCH_TO_CORP permit ip 172.31.0.0 0.0.0.7 192.168.69.0 0.0.0.255
            access-list ACL_VPN_BRANCH_TO_CORP permit ip 172.31.0.0 0.0.0.7 10.110.0.0 0.0.0.255
            access-list ACL_VPN_BRANCH_TO_CORP deny ip any any
        Current peer: 1.4.2.8
        Security association lifetime: 4608000 kilobytes/3600 seconds
        PFS (Y/N): N
        Transform sets={
        Interfaces using crypto map BRANCH_TO_CORP_VPN:
                GigabitEthernet0/0
HQ ROUTER
ping 172.31.0.1
Sending 5, 100-byte ICMP Echos to 172.31.0.1, timeout is 2 seconds:
U...U
HOME ROUTER
ping 192.168.69.1 source 172.31.0.1
Sending 5, 100-byte ICMP Echos to 192.168.69.1, timeout is 2 seconds:
Packet sent with a source address of 172.31.0.1
Success rate is 0 percent (0/5)
ping 4.2.2.2 source 172.31.0.1
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/26/28 ms
HQ ROUTER
show crypto engine connections active
Crypto Engine Connections
   ID  Type    Algorithm           Encrypt  Decrypt LastSeqN IP-Address
1139  IPsec   AES+SHA512                0      143      143 12.4.2.8
 1140  IPsec   AES+SHA512              143        0        0 1.4.2.8
 1161  IPsec   AES+SHA512                0      102      102 1.4.2.8
 1162  IPsec   AES+SHA512                0        0        0 1.4.2.8
 1163  IPsec   AES+SHA512                0        4        4 1.4.2.8
 1164  IPsec   AES+SHA512                0        0        0 1.4.2.8
11086  IKE     SHA512+AES256             0        0        0 1.4.2.8
11087  IKE     SHA512+AES256             0        0        0 1.4.2.8
11088  IKE     SHA512+AES256             0        0        0 1.4.2.8
HOME ROUTER
 1042  IKE     SHA512+AES256             0        0        0 2.1.1.3
 2055  IPsec   AES+SHA512                0        0        0 2.1.1.3
 2056  IPsec   AES+SHA512               91        0        0 2.1.1.3
 2057  IPsec   AES+SHA512                0        0        0 2.1.1.3
 2058  IPsec   AES+SHA512                4        0        0 2.1.1.3
HQ ROUTER
show crypto session detail
Crypto session current status
Interface: Tunnel0 * DMVPN VPN tunnel
Uptime: 3d05h
Session status: UP-ACTIVE
Peer: 192.168.69.252 port 500 fvrf: (none) ivrf: (none)
      Phase1_id: 192.168.69.252
      Desc: (none)
  Session ID: 0
  IKEv1 SA: local 1.4.2.8/500 remote 192.168.69.252/500 Active
          Capabilities:D connid:11086 lifetime:00:15:00
  Session ID: 0
          Capabilities:D connid:11087 lifetime:00:15:00
  IPSEC FLOW: permit 47 host 1.4.2.8 host 192.168.69.252
        Active SAs: 2, origin: crypto map
        Inbound:  #pkts dec'ed 7758 drop 0 life (KB/Sec) 4323776/16 hours, 5 mins
        Outbound: #pkts enc'ed 7759 drop 0 life (KB/Sec) 4323774/16 hours, 5 mins
Interface: GigabitEthernet0/2
Uptime: 00:06:42
Peer: 12.187.12.133 port 500 fvrf: (none) ivrf: (none)
      Phase1_id: 12.187.12.133
      Desc: (none)
  Session ID: 0
  IKEv1 SA: local 1.4.2.8/500 remote 2.1.1.3/500 Active
          Capabilities:D connid:11088 lifetime:00:53:16
  IPSEC FLOW: permit ip 192.168.69.0/255.255.255.0 172.31.0.0/255.255.255.248
        Active SAs: 2, origin: dynamic crypto map
        Inbound:  #pkts dec'ed 4 drop 0 life (KB/Sec) 4252213/3473
        Outbound: #pkts enc'ed 0 drop 0 life (KB/Sec) 4252214/3473
  IPSEC FLOW: permit ip 10.110.0.0/255.255.255.0 172.31.0.0/255.255.255.248
        Inbound:  #pkts dec'ed 65 drop 0 life (KB/Sec) 4371659/3197
        Outbound: #pkts enc'ed 0 drop 0 life (KB/Sec) 4371667/3197
HOME ROUTER
Interface: GigabitEthernet0/0
Uptime: 00:02:27
Peer: 12.45.217.58 port 500 fvrf: (none) ivrf: (none)
      Phase1_id: 1.4.2.8
      Desc: (none)
  Session ID: 0
  IKEv1 SA: local 2.1.1.3/500 remote 1.4.2.8/500 Active
          Capabilities:D connid:1042 lifetime:00:57:30
  IPSEC FLOW: deny ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
        Active SAs: 0, origin: crypto map
        Inbound:  #pkts dec'ed 0 drop 0 life (KB/Sec) NA/NA
        Outbound: #pkts enc'ed 0 drop 0 life (KB/Sec) NA/NA
  IPSEC FLOW: permit ip 172.31.0.0/255.255.255.248 192.168.69.0/255.255.255.0
        Inbound:  #pkts dec'ed 0 drop 0 life (KB/Sec) 0/0
        Outbound: #pkts enc'ed 0 drop 0 life (KB/Sec) 0/0
  IPSEC FLOW: permit ip 172.31.0.0/255.255.255.248 10.110.0.0/255.255.255.0
        Inbound:  #pkts dec'ed 0 drop 0 life (KB/Sec) 4204120/3452
        Outbound: #pkts enc'ed 28 drop 0 life (KB/Sec) 4204117/3452
  IPSEC FLOW: permit ip 172.31.0.0/255.255.255.248 192.168.50.0/255.255.255.0
Cristian Matei
    Yes, DMVPN can co-exist with other VPN technologies configured on the same device. As far as i understand from your statements and by looking at the configs, the IKE and IPsec tunnel are up, it's just data-plane which does not seem to be working. It seems that HQ router received encrypted packets, but fails to send back, as you forgot to exclude VPN traffic form your NAT configuration on the HQ router, so packets get NAT'ed, no longer match the crypto ACL, thus are never sent back through the tunnel. Fix it, and if it doesn't work, generate traffic for all 3 networks you want to be reachable from HQ, and paste the following outputs:
HQ NAT FIX:
ip access-list extended 151
 1 deny ip 192.168.50.0 0.0.0.255 172.31.0.0 0.0.0.7
 2 deny ip 192.168.69.0 0.0.0.255 172.31.0.0 0.0.0.7
 3 deny ip 10.110.0.0 0.0.0.255 172.31.0.0 0.0.0.7
Collect outputs:
show crypto isakmp sa
show crypto IPsec sa peer x.y.z.w
show crypto session remote x.y.z.w detail
Cristian Matei.
Cristian Matei
HQ NAT FIX:
Collect outputs:
Cristian Matei.
