Additional route for Backup line.
Hi all,
Currently our Site A router have 1 default route ( to Internet ) and BGP route to the branches.
The primary line is using BGP to connect to the branches.
Now, our ISP gave us ADSL secondary line as a Backup for the primary line.
I already configure the PPPOE connection and I get the IP for Backup line.
But my question is what route should i configure for the Backup line to kick-in once the Primary line down.
Default route still need to go to the Internet.
5 Replies 5
anyone can help
Could you please provide following info ?
Is your ISP giving you Real IP's or Dynamic IPs ?
I assume the provider does not peer BGP with you on the ADSL line. I suggest you use floating static routes.
i don't know , the ADSL is a secondary backup to the existing primary line which using BGP.
How are the routing should be??? Please help.
when connected, it will get fix IP
