04-23-2009 06:17 AM - edited 03-04-2019 04:29 AM
I have am using DMVPN which is working perfectly for domestic sites but as soon as I start using routers overseas I am getting the following error:
%ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of Tunnel1, addr 10.48.12.2 854E1580 - looped chain attempting to stack
These routers are the exact same routers that we use in the United States and we are using the same config. I have no idea what's going on here.
Right now I have only one tunnel connecting to the routers and it's still complaining about the loop.
I've attached the config..
Thanks!!
Building configuration...
crypto isakmp policy 1
encr aes 256
hash md5
authentication pre-share
group 2
crypto isakmp key <removed> address 0.0.0.0 0.0.0.0 no-xauth
crypto ipsec transform-set AES esp-aes 256 esp-md5-hmac
mode transport
crypto ipsec profile AAA_VPN_2.0
set transform-set AES
bridge irb
interface Loopback0
ip address 10.100.1.52 255.255.255.255
interface Tunnel1
bandwidth 1500
ip address 10.48.12.22 255.255.254.0
no ip redirects
ip mtu 1200
ip nhrp authentication VPN20_T1
ip nhrp map 10.48.12.2 1.1.1.1
ip nhrp map 10.48.12.1 2.2.2.2
ip nhrp map multicast 1.1.1.1
ip nhrp map multicast 2.2.2.2
ip nhrp network-id 1
ip nhrp nhs 10.48.12.2
ip nhrp nhs 10.48.12.1
ip nhrp registration no-unique
tunnel source FastEthernet4
tunnel mode gre multipoint
tunnel protection ipsec profile AAA_VPN_2.0
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 10.32.50.1 255.255.255.0
ip nat inside
router eigrp 10
passive-interface default
no passive-interface Tunnel1
network 10.48.12.22 0.0.0.0
network 10.100.1.52 0.0.0.0
no auto-summary
logging dmvpn
tacacs-server host 172.27.10.212 key 7 <removed>
tacacs-server host 10.2.100.208 key 7 <removed>
tacacs-server directed-request
control-plane
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
transport input ssh
scheduler max-task-time 5000
end
08-27-2020 02:35 PM
Sergio
You are welcome. Yes it is an old discussion, and I am happy to see that it continues to be helpful. It is a pretty unusual symptom and the error message is not very helpful in identifying the cause of the problem. Well deserved +5 for bringing this discussion back into view.
I realize in reading through the discussion that I only indirectly acknowledge the work of the TAC engineers to help me find the root cause of this symptom. So I would like to offer my belated thanks to those skillful engineers.
04-12-2023 12:29 AM
Hello, I have run into the same issue when simply making a packet tracer activity, the error looks like this
R2> %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
01:37:12: %OSPF-5-ADJCHG: Process 10, Nbr 5.5.5.5 on Tunnel10 from LOADING to FULL, Loading Done
R2> %ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of 10 65E900C0 - looped chain attempting to stack
%TUN-5-RECURDOWN: 10 temporarily disabled due to recursive routing
%LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
01:37:17: %OSPF-5-ADJCHG: Process 10, Nbr 5.5.5.5 on Tunnel10 from FULL to DOWN, Neighbor Down: Interface down or detached
ISP router has only interfaces ip addresses, nothing else
04-13-2023 03:01 AM
Tried setting 111 AD for ip route 0.0.0.0 0.0.0.0 1.1.1.1 111 (to override ospf)
Tried static route straight to tunnel interface - doesn't work at all
No matter with or without PAT
04-13-2023 03:12 AM
Share this issue in separate link I will check and find solution for it
04-13-2023 02:48 PM
Am I correct in understanding that this is being done in Packet Tracer? If so we may need to consider that it is some issue with PT. I find it strange (and frustrating) that some of the messages have time stamp but most do not. Are the log messages perhaps generated from different processes?
This is a very old discussion, with multiple occurrences of the midchain parent maintenance issue. The common finding is that the issue is caused when there is a static route for the tunnel endpoint and a dynamic routing protocol running over the tunnel. As best as I can determine that seems to be the case here. And in the previous cases the issue was caused when the physical interface changed state to protocol down. We do not have enough information about the current case to know if that is the case, but I suspect that either it is the case, or we have encountered another strange misbehavior in PT.
04-14-2023 10:20 AM
i believe in my case it's either a bug or my mistake. OSPF Adjchg error, adj-5-parent error, recursive routing error in PT - this is my issue
