ADSL PPPoE configuration
tarekesmail
ADSL PPPoE Static IP Problem
I have CISCO 1841 Router with ADSL WIC, i have configured the PPPoE information and get the internet on the router but the addresses is negotiated, but i have /29 IP Addresses for example
188.99.99.99.15
188.99.99.99.16
188.99.99.99.17
188.99.99.99.19
188.99.99.99.19
and the Gateway is : 188.99.99.99.14
I need this IPs to working on the router also i have dialer0 with auto negotiated IP address and i need the subnet 192.168.2.0/24 redirect to one of this static IPs, and i need to configure the static IPs in connected servers and the private IPs to computers
Thanks in advance
5 Replies 5
Philip D'Ath
Does the router get a negotiated address inside of your /29, or something completely different?
NO It's gives another ip in different range
Is the ISP routing your /29 to you via that IP address then?
I'm don't know but this IPs routing to my network and PPPoE, i have this subnet and gateway from the provider, also please note the provider support team don't have any knowledge about this mission or this task, also another note if i used any other small router like Linksys ADSL +2 Router the IPs working fine after changing the linksys IP to the gateway without any issue
Hi, Some days ago I have faced the same issue in the INDIA with BSNL service provider. After discussion with ISP, I have configured the router as below:
1. Configured Dial-up and get a normal IP from ISP.
2. Make a Look back interface and assigned an IP public IP to loopback.
3. Added a default route toward to default gateway.
4. IP nat outside is added to lookback interface etc.
I will try to get a backup copy of that router and If will get then I will share the correct configuration with you.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
