12-02-2021
08:12 PM
- last edited on
12-05-2021
09:54 PM
by
Translator
As per the business requirement, we need to aggregate two WAN links that are connecting from the data center to a branch office. At both locations, we are having C9500-24Y4C switches and I have configured both the physical interfaces with LACP. Hove ever the EtherChannel is not forming. I have checked the LACP counter status and only the "Send" count is incrementing. Seems both devices are sending but not receiving the LACPDUs. Our WAN underlay network is a VPLS provided by a third-party WAN provider.
I have requested to enable LACPDUs over the VPLS network, and the WAN provider confirmed that they enabled the same from their end but still no luck.
Are there any additional configurations that need to be done from our end apart from the default LACP configs?
The current configuration in the DC end is below
interface TwentyFiveGigE1/0/5
channel-group 14 mode active
end
interface TwentyFiveGigE2/0/5
end
Solved! Go to Solution.
12-03-2021
01:50 AM
- last edited on
12-05-2021
11:30 PM
by
Translator
Couple of things to check here :
1. VPLS from provider looks good, what kind oif Delivery Fibre or Ethernet ?
2. what kind of speed link ( 1G or 10GB ?)
3. these 25Gig port, so you using right Optic and ports come up as below mentioned.
4. Do you see on the port on Cat 9500 come up ? when you Plug VPLS connect to switch (both the sides)
5. have you enabled CDP neighbour, can you see each other switch both the sides ?
if all yes then :
switchport
switchport
end
if you like to load-balance different options available once the LACP working :
port-channel load-balance { dst-ip | dst-mac | dst-mixed-ip-port | dst-port | extended [ dst-ip | dst-mac | dst-port | ipv6-label | l3-proto | src-ip | src-mac | src-port ] | src-dst-ip | src-dst-mac src-dst-mixed-ip-port src-dst-portsrc-ip | src-mac | src-mixed-ip-port | src-port | vlan-dst-ip | vlan-dst-mixed-ip-port | vlan-src-dst-ip | vlan-src-dst-mixed-ip-port | vlan-src-ip | vlan-src-mixed-ip-port }
12-02-2021
09:58 PM
- last edited on
12-05-2021
09:57 PM
by
Translator
here is example for LACP configuration:
in this example we assigns two trunk ports in VLAN 10 to channel 2 with the LACP mode active:
Device# configure terminal
Device(config)# interface range TwentyFiveGigE 1/0/1-2
Device(config-if-range)# switchport mode trunk
Device(config-if-range)# switchport trunk allowed vlan add 10
Device(config-if-range)# channel-group 2 mode active
Device(config-if-range)# end
interface port-channel2
By the way, in a similar case we had several months ago with the same C9500 a switchport trunk native vlan <x> command was missing
12-03-2021 12:30 AM - edited 12-03-2021 12:32 AM
Hello
For a layer two PC you way you have initially done this is correct,
Once the physical interfaces have been applied to the port -channel then the logical interface will be automatically created (meaning don't create this yourself), Then, in that PC interface you apply your trunking etc which will then be applied to the physical interfaces automatically
12-03-2021
01:50 AM
- last edited on
12-05-2021
11:30 PM
by
Translator
if all yes then :
switchport
switchport
end
12-03-2021 07:47 PM
Hi Balaji. I have checked and verified all the steps you have mentioned above and all are good. However, the issue was with the WAN provider. They did some changes at their end and after that port channel formed successfully. Thanks.
12-05-2021 11:33 PM
just out of curiosity, what was the issue, and how did the WAN provider fix it ?
