ASA 5550 Behind ISP Router
TylerPeppy
Spoiler
Hi all, recently got my hands on an ASA 5550 and I was trying to configure it as a device on my homelab network in which it would be behind a Pre-Existing NAT with a DHCP server enabled. I configured the Firewall in transparent mode but can't pass traffic from an outside interface to an inside interface, which connects to a switch distributing the connection to the rest of my homelab devices. How should I do this?
Regards, Tyler
can you share config again I couldnot see it
balaji.bandi
simple setup that works as expected : still issue post the config  and version of ASA running.
https://www.balajibandi.com/?p=1727
BB
Yes I have seen this guide previously although, I do not have the switchport command, using ASA 9.17. I will post the config later when I can.
Sure post the config also post show firewall output.
BB
