ASA 9.8 How to export self-signed certificate?
ac5nwdude
Hello folks,
I just configured SSLVPN on an ASA 9.8 for the first time - it works as expected. However, users connecting to the ASA get a warning from Cisco AnyConnect: "Security Warning: Untrusted Server Certificate!".
This makes sense as I generated a self-signed certificate on the ASA itself:
fw01-1(config)# crypto key generate rsa label sslvpnkey
fw01-1(config)# crypto ca trustpoint localtrust
fw01-1(config-ca-trustpoint)# enrollment self
fw01-1(config-ca-trustpoint)# fqdn sslvpn.foo.bar
fw01-1(config-ca-trustpoint)# subject-name CN=sslvpn.foo.bar
fw01-1(config-ca-trustpoint)# keypair sslvpnkey
fw01-1(config-ca-trustpoint)# crypto ca enroll localtrust noconfirm
fw01-1(config)# ssl trust-point localtrust OUSIDE_WAN
My idea is to export the certificate from the ASA and roll it out to the clients as a trusted local certificate. However, I dont see any certificates, trustpoints etc. in ASDM nor on the CLI:
fw01-1# show crypto ca trustpoints
fw01-1# show crypto ca certificates
(above commands don't give any output)
What am I doing wrong?
Thanks in advance!
It is much easier: Go to your https-FQDN with Firefox, click on the certificate icon and in the details of the certificate view you can export the certificate. This way you also make sure that you don't accidentally export the private key of your certificate.
