ASR1001 Restrict telnet IPv6
fabienfs
I use access-list to restrict access to telnet.
How to adapt this rule to also restrict telnet access in IPv6?
access-list 50 remark ---Restrict Telnet Access---
access-list 50 permit xx.xx.xx.xx 0.0.3.255
access-list 50 deny any
Do I need to add something like this?
access-list 50 remark ---Restrict Telnet Access IPv6---
access-list 50 permit 2A0A:xxx:xxx:xxxx/?
thanks for your help :-)
there is (the same as in IPv4 access lists) and implicit deny at the end. Here is what the ACL for just Telnet would look like:
ipv6 access-list RESTRICT_TELNET_IPv6_ACL
permit tcp 2A0A:DB2:0200::/64 eq telnet any
line vty 0 4
ipv6 access-class RESTRICT_TELNET_IPv6_ACL in
balaji.bandi
the syntax will be bit different,  refer below guide  has different examples:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_data_acl/configuration/xe-3s/sec-data-acl-xe-3s-book/ip6-acls-xe.html
BB
line vty 0 4
thanks!
