ASR1001-X Memory
zekebashi
Level 4
Level 4
On our ASR1001-X, the show ver command outputs 8388608K bytes of physical memory and I was trying to find a CLI command that would show me which slots are occupied by DIMMS and which slots are available? Is there such a command(s)? Or, should I just assume that all 4 slots are occupied by 2 DMMS in each slot (default?
Thanks in advance, ~zK
I think 'show platform' lists the slots that are in use...
Have tried that command but it doesn't show the DIMMs slots:
sh platform
Chassis type: ASR1001-X
Slot             Type                                 State           Insert time (ago)
0             ASR1001-X                           ok                8w3d
0/0          BUILT-IN-2T+6X1GE              ok               8w3d
R0           ASR1001-X                           ok, active    8w3d
F0           ASR1001-X                           ok, active    8w3d
P0          ASR1001-X-PWR-AC            ok               8w3d
P1          ASR1001-X-PWR-AC            ok               8w3d
P2          ASR1001-X-FANTRAY           ok               8w3d
Slot         CPLD Version                    Firmware Version
0             14041015                         16.2(1r)
R0           14041015                         16.2(1r)
F0           14041015                          16.2(1r)
Try offload time
show tech-support
BB
Leo Laohoo
There is always a pair of memory "sticks".
One cannot "add" memory sticks.
You need to buy the new sticks and then REPLACE the existing ones.
