ASR920 Port Channel down in L2 on service instance
M.Fly
we have a ASR920 facing an ASR9K with 2 10G Link.
We have configured Port Channel on ASR920 like this:
interface Port-channel1
description ***LAG***
no ip address
no negotiation auto
service instance 1 ethernet
encapsulation untagged
l2protocol peer stp dot1x lacp
bridge-domain 1
service instance 2 ethernet
encapsulation dot1q 2 second-dot1q 1-4094
bridge-domain 2
The 2 single port like this:
interface TenGigabitEthernet0/0/24
description ***port1***
no ip address
udld port
channel-group 1 mode active
interface TenGigabitEthernet0/0/25
description ***port2***
no ip address
udld port
 We do not have control of ASR9K, is a router of the carrier.
The Port Channel 1 is down/down on ASR920, LACP not negotiate and the sh etherchannel summary report this:
Flags: D - down P/bndl - bundled in port-channel
I - stand-alone s/susp - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(RD) LACP Te0/0/24(susp) Te0/0/25(susp)
RU - L3 port-channel UP State
SU - L2 port-channel UP state
P/bndl - Bundled
S/susp - Suspended
The status seems in L3 and not L2, the port channel don't bring up protocol, where is/are the problem?
6 Replies 6
Mark Elsen
                      >....We do not have control of ASR9K, is a router of the carrier.
  - It will  be difficult to resolve this issue then, at least feedback on remote configuration such be given and logs , also different LACP modes should be tried and be able to do so at both sides ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hello
Are you supposed to be bridging towards the ISP or should it be a pure layer LAG?
Kind Regards
Paul
We have the configuration of end point of the carrier:
bundle
interface Bundle-Ether185
description FO
mtu 9144
load-interval 30
dampening
and interface:
description FO
bundle id 185 mode active
lacp period short
carrier-delay up 1000 down 0
load-interval 30
dampening
 - You need to debug with the carrier such as asking interface status(es) , counters , logs , ... (when connection attempt is being made)
 M.
       Beauty and terror
      Just keep going
       No feeling is final
This is a debug lacp all on my ASR920:
*Jan 19 22:30:56.791: LACP: update_Selected_Actor: Actor LAG components have changed,Unselecting Te0/0/24.
*Jan 19 22:30:56.791: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:30:56.791: LACP: lacp_handle_standby_port: No Standby port found for LAG 1
*Jan 19 22:30:57.190: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:30:57.459: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:30:57.801: LACP: update_Selected_Actor: Actor LAG components have changed,Unselecting Te0/0/24.
*Jan 19 22:30:57.801: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:30:57.801: LACP: lacp_handle_standby_port: No Standby port found for LAG 1
*Jan 19 22:30:58.134: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:30:58.410: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:30:58.811: LACP: update_Selected_Actor: Actor LAG components have changed,Unselecting Te0/0/24.
*Jan 19 22:30:58.811: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:30:58.811: LACP: lacp_handle_standby_port: No Standby port found for LAG 1
*Jan 19 22:30:59.058: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:30:59.290: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:30:59.821: LACP: update_Selected_Actor: Actor LAG components have changed,Unselecting Te0/0/24.
*Jan 19 22:30:59.821: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:30:59.821: LACP: lacp_handle_standby_port: No Standby port found for LAG 1
*Jan 19 22:30:59.942: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:31:00.186: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Jan 19 22:31:00.831: LACP: update_Selected_Actor: Actor LAG components have changed,Unselecting Te0/0/24.
Here is the debug show from the ASR9K of carrier ethernet:
show bundle bundle-ether 185
Bundle-Ether185
  Status:                                    Down
  Local links <active/standby/configured>:   0 / 0 / 2
  Local bandwidth <effective/available>:     0 (0) kbps
  MAC address (source):                      b026.806b.ea29 (Chassis pool)
  Inter-chassis link:                        No
  Minimum active links / bandwidth:          1 / 1 kbps
  Maximum active links:                      64
  Wait while timer:                          2000 ms
  Load balancing:
    Link order signaling:                    Not configured
    Hash type:                               Default
    Locality threshold:                      None
  LACP:                                      Operational
    Flap suppression timer:                  Off
    Cisco extensions:                        Disabled
    Non-revertive:                           Disabled
  mLACP:                                     Not configured
  IPv4 BFD:                                  Not configured
  IPv6 BFD:                                  Not configured
  Port                  Device           State        Port ID         B/W, kbps
  Te0/4/0/3             Local            Negotiating  0x8000, 0x0030    10000000
      Partner has not echoed the correct parameters for this link
  Te0/4/0/4             Local            Negotiating  0x8000, 0x002f    10000000
 Have you any idea of configuration problem or interoperability problem?
