ATOM Cisco 7206VXR (NPE-G2)
mrcomm2000
I try to configure ATOM in two 7206VXR (NPE-G2) routers as the following
-first router
interface ATM2/0.100 point-to-point
no snmp trap link-status
pvc 0/1234 l2transport
xconnect 10.1.1.1 50 encapsulation mpls
-second router
xconnect 10.1.1.2 50 encapsulation mpls
But vc is down
Local intf Local circuit Dest address VC ID Status
AT2/0.100 ATM AAL5 0/100 10.1.1.1 50 DOWN
I need to know if 7206VXR (NPE-G2) support ATOM configuration or not
PE#show ver
Cisco IOS Software, 7200 Software (C7200P-ADVIPSERVICESK9-M), Version 12.4(11)T1, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 25-Jan-07 20:33 by prod_rel_team
ROM: System Bootstrap, Version 12.4(4r)XD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD2, RELEASE SOFTWARE (fc2)
Suez_PE uptime is 1 week, 3 days, 5 minutes
System returned to ROM by reload at 11:20:47 CAI Wed May 16 2007
System restarted at 19:29:04 CAI Wed May 16 2007
System image file is "disk2:c7200p-advipservicesk9-mz.124-11.T1.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 35245323
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.1
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 90 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 270 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2 Serial interfaces
2 ATM interfaces
2045K bytes of NVRAM.
500472K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
mohammedmahmoud
Level 11
Level 11
According to Cisco Feature Navigator, your router and the IOS it runs should run AToM, please check this document for relevant AToM configuration:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1838/products_feature_guide_book09186a0080134a17.html
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Dear mohhamed
I made the same configuration in 2 routers Cisco 7206VXR (NPE-G1) with IOS c7200-js-mz.123-8.T5.bin and vc is up
AT1/0.300 ATM AAL5 2/300 10.1.1.3 300 UP
Please advice
thank you
If same configuration fails on the newer IOS/NPE, suggest you contact the TAC for the due support.
Rahul Kachalia
If possible pls provide output of following cmds:
s int at2/0
s mpls l2 vc det
s mpls int
s mpls ldp neighbor
s ip route 10.1.1.1
s ip route 10.1.1.2
thanks,
rahul.
