backup interface support on ASR
Muhammed AKYUZ
do you know backup interface is supported on ASR?
interface GigabitEthernet0/2/1
description 3750_Stack_1
backup interface GigabitEthernet0/2/2
ip address 100.50.50.242 255.255.255.248
end
description 3750_Stack_2
end
TTVPN#sh ip int brief
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0/0   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0/1   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0/2   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0/3   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0/4   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0/5   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0/6   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0/7   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/2/0   unassigned      YES NVRAM  up                    up
Gi0/2/0.90             100.50.90.253   YES NVRAM  up                    up
GigabitEthernet0/2/1   100.50.50.242   YES NVRAM  up                    up
GigabitEthernet0/2/2   100.50.50.242   YES NVRAM  up                    up
GigabitEthernet0/2/3   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/2/4   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/2/5   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/2/6   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/2/7   unassigned      YES NVRAM  administratively down down
GigabitEthernet0       unassigned      YES NVRAM  administratively down down
TTVPN#
7 Replies 7
Edison Ortiz
Backup interface is supported on serial or ISDN interfaces. Routers do not support backup interface on Ethernet.
Edison
Giuseppe Larosa
the right tool to use is an LACP aggregate inteface configured at L3 towards the C3750 stack, it can be configured in the same way on the C3750.
if this would be unsupported on ASR  I would look for using IRB on ASR side.
if even this is unsupported use two indipendent L3 links with an IGP running on both of them.
Hope to help
Giuseppe
Giuseppe,
There is support for link bundling w/ ASR and your suggestion is the right one for this case
http://www.cisco.com/en/US/docs/ios/ios_xe/cether/configuration/guide/ce_lnkbndl_xe_ps9587_TSD_Products_Configuration_Guide_Chapter.html
Edison
Edison,
I have used bundles on IOS XR with 12000 so my guess was based on this fact.
it is better to provide links when possible, but I was short of time when I have answered.
Best Regards
Giuseppe
you can do that on 7200 for ethernet..
R3#sh ip int brie
FastEthernet0/0            unassigned      YES NVRAM  administratively down down
FastEthernet1/0            1.1.1.3         YES NVRAM  up                    up
FastEthernet1/1            1.1.1.3         YES manual standby mode          down
we have solved the problem by upgrading the software
Dear akyuznet45;
can you share the configurations of 7200 for ethernet
