bandwidth management on Cisco switch
atuljoshig
Can some one help me to solve my issue? I have 2 cisco switches how can i manage the bandwidth on those switches. Also is this possible to do on 2900 and 3524xl series or i have to buy any other switch on which i can manage the bandwidth. Please help me to sort my problem.
Looking for your advice.
ebreniz
Level 6
Level 6
The switch can limit the bandwidth or the number of concurrent sessions available for each shared Web site, allowing service providers to charge for, and deliver, services based on each unique needs.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea5/configuration/guide/swqos.html
shivlu jain
Level 5
Level 5
you ca use on 35XX switches the given below command for rate limiting
srr-queue bandwidth limit 75
shivlu
Mohamed Sobair
Level 7
Level 7
Managing Bandwidth has lots of meaning, If you mean manage QoS on Switches, then Edison had provided a useful link you can use.
If you mean bandwidth managing (limitation) , then this is totally different.
Mohamed
