bandwidth shape or limit per subnet 2801
danletkeman
I have a 2801 doing pbr routing by source ip to 4 different gateways.
interface FastEthernet0/0
description lan
bandwidth 100000
ip address 10.1.10.1 255.255.255.0
ip nat inside
ip route-cache flow
ip policy route-map inet
duplex auto
speed auto
interface FastEthernet0/1
description wan
bandwidth 14000
ip address 10.10.50.1 255.255.255.0
duplex auto
speed auto
ip classless
ip access-list extended dto
permit ip 192.168.18.0 0.0.0.255 any
ip access-list extended ees
permit ip 192.168.6.0 0.0.0.255 any
ip access-list extended ges
permit ip 192.168.4.0 0.0.0.255 any
ip access-list extended lis
permit ip 192.168.8.0 0.0.0.255 any
route-map inet permit 40
match ip address ges
set ip next-hop 10.10.50.103
route-map inet permit 60
match ip address ees
set ip next-hop 10.10.50.102
route-map inet permit 80
match ip address lis
set ip next-hop 10.10.50.101
route-map inet permit 180
match ip address dto
set ip next-hop 10.10.50.104
Each gateway is an ADSL line with 3mbit down and 384kbit up. The above is just an example of the pbr that is happening, there are more subnets than shown. I would like to setup bandwidth shaping or rate limiting so that one ip from one subnet will not hog the whole adsl line.
If someone could please provide an example of a policy map that I can apply to an interface so I can shape or limit the traffic. I have tried a few things but I can never get anything to rate limit or police.
Dan.
paolo bevilacqua
Hi Dan,
In practice, you can only limit and set fair share for the upload direction. To do this, you will need to traffic-shape output to be same speed as your DSL line, see this document:
http://cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800b2d29.shtml
The alternative is to place the ADSL interfaces directly in the router (HWIC-1ADSL), this would make all the above automatic.
For input, there isn't really much that you can do, because you do not control the upstream router, where the congestion occurs.
oschaul2
This should work for you:
class-map match-any dto
match access-group name dto
class-map match-any ees
match access-group name ees
class-map match-any ges
match access-group name ges
class-map match-any lis
match access-group name lis
policy-map outwan
class dto
  shape average 384000
class ees
class ges
class lis
class class-default
  fair-queue
description wan
bandwidth 14000
service-policy output outwan
duplex auto
speed auto
