been through ssh set up several times!!!!
Choose the size of the key modulus in the range of 360 to 2048 for your
General Purpose Keys. Choosing a key modulus greater than 512 may take
a few minutes.
How many bits in the modulus [512]: 2048
% Generating 2048 bit RSA keys, keys will be non-exportable...[OK]
sshrouter(config)#ip ssh version 2
*Mar 1 0:45:58.864: %SSH-5-ENABLED: SSH 1.99 has been enabled
sshrouter(config)#
sshrouter(config)#
sshrouter(config)#sh ssh
% Invalid input detected at '^' marker.
sshrouter(config)#do sh ssh
%No SSHv2 server connections running.
%No SSHv1 server connections running.
I have been back and used
#crypto key zeroize rsa
Then restarted again but cannot get it to work
sshrouter(config)#
sshrouter(config)#
sshrouter(config)#do sh ip ssh
SSH Disabled - version 2
%Please create RSA keys (of atleast 768 bits size) to enable SSH v2.
Authentication timeout: 120 secs; Authentication retries: 3
sshrouter(config)#ip domain-name cisco.com
sshrouter(config)#crypto key generate rsa
The name for the keys will be: sshrouter.cisco.com
a few minutes.
*Mar 1 0:50:1.838: %SSH-5-ENABLED: SSH 2 has been enabled
sshrouter(config)#
sshrouter(config)#transport input ssh
 This is probably GNS3, correct?
If GNS3 dont waste time on this router. Just add another router and repeat the process which is really simple and you know already.
aaa new-model
ip domain-names 'domain'
hostname 'hostname
crypto key generate rsa 'key'
ip ssh version 2
 I just had the same problem here. Tried many times in one router with no success and then the other I got  it to work with the same process.
ciscp#sh ssh
Connection Version Mode Encryption Hmac State Username
0 2.0 IN aes256-cbc hmac-sha1 Keys exchanged -
0 2.0 OUT aes256-cbc hmac-sha1 Keys exchanged -
Hi, doing this in packet tracer on a 2910
have had this work before but just can't get it to work today
For Packet Tracer, even though the router shows :
Goes to a machine and fire up an SSH session. I got this same situation as well.
After tried to access, the service came up
myrouter(config)#do show ss
323 1.99 IN aes128-cbc hmac-sha1 Session Started flavio
323 1.99 OUT aes128-cbc hmac-sha1 Session Started flavio
try to ssh device after correct process you did. it will work even though it says server is not running.
Good luck
KB
