OSPF not enabled on FastEthernet0/0
zunairamalik141
Hi everyone, I simply configure f0/0 and ospf on R1 but it is not working. anyone tell me why is it happening?
pman
change network 203.10.1.2 0.0.0.255 area 0 to network 203.10.1.0 0.0.0.255 area 0 on both sides
Hello
Either do one of the following
int fa0/0
ip ospf 1 area 0
or
router ospf 1
Network 203.10.1.2 0.0.0.0 area 0
Kind Regards
Paul
Friend if you want to check it work or not
Do
Show ip ospf database
Or
Show ip ospf  interface
Show ip route not help you here
It most likely is working. It is directly connected which is a lower AD than the OSPF process so it will show as connected over OSPF in the routing table. If you have another router in the network that is NOT directly connected and a neighbor of the OSPF process you can verify. YOu can also do a "show ip protocols" command to see what networks OSPF is routing for.
Hope that helps
-David
