BGP default route
redcoruna
I have a issue because I have a single router for do multihomed, this router haven't enough ram memory (256 MB) for full table. My peers send me two default route but I want load sharing because now only out by a peer.
How can I load sharing with this scheme ?
Thank you,
Regards.
12 Replies 12
paolo bevilacqua
From one peer, accept by fiter just some as paths that you want to reach that side. Use default to the other. That's for outgoing, incoming could load share by itself.
That's what I thought, but if that down neighbor sends me the default route?
You can always filter it out, or even better, have a local preference for another default.
Edison Ortiz
Did you try implementing maximum paths ?
http://www.cisco.com/warp/public/459/40.html
HTH,
__
Edison.
But the problem is that I haven't nothing in my routing table, you can see the command "show ip bgp":
Network Next Hop Metric LocPrf Weight Path
* 0.0.0.0 ISP-A 0 0 AS(ISP-A) i
*> ISP-B 0 0 AS(ISP-B) i
If I set a route-map only to ISP-A how the following:
neighbord ISP-A route-map UPDATE-IN in
route-map UPDATE-IN permit 10
match ip address 1
set weight 200
access-list 1 permit RANGE MASK
Sorry, long time has passed since I did BGP last time. Check if the ACl matches. Check the full bgp entry, what weight currently ? You can apply weight even directly on neighbor. Then you you have no routes, is because they are not sending any :)
Thank friend.
I can't receive full table because my router have little ram :) . I go to will do with as-path. When I have done, I will post.
Luis,
BGP will not to load balance by default on paths received from different ASes. You will need the following command to change this default behavior:
router bgp
bgp bestpath as-path multipath-relax
You will also need to use "maximum-paths 2" as suggested by Edison.
This will allow you to load balance between the two default routes.
Thank Harold and others,
But I need have a peer with in weight 100 and a default route and the other provider backup with a default route and a weight 50, and I will request to this provider a full table for filter two ASN with a weight 200.
I thought in this configuration, but I not am secure:
neighbor ISP-A weight 50
neighbor ISP-A route-map TIMOFONICA in
route-map TIMOFONICA permit 10
match as-path 5
set weight 200
ip as-path access-list 5 permit ^3352$
ip as-path access-list 5 deny ^$
Regards.
Hello redcoruna,
if you want to receive a default route from ISP-A you need and additional route map block that allows it, otherwise you will see only the prefixes that have AS path = 3352
or also the default route will have weight 200 if its AS path = 3352
so you should add the following before:
ip prefix-list only-default permit 0.0.0.0/0
route-map TIMOFONICA permit 5
match ip address prefix-list only-default
this way you accept the default route but you have weight 50, the second block will accept with an increased weight all the other prefixes with AS path = 3352
best regards
Giuseppe
Yep... rated post :)
Very good posted, other idea if you ISP will not provide of full table + default route can be:
- Request full route and you create yourself a default route:
ip route 0.0.0.0 0.0.0.0 INTERFACE DISTANCE-ADMINISTRATIVE
Luis
