BGP on CISCo 2801
c3303603
hello, I need to run BGP on CISCO 2801, and have currently IOS 2801 Software (C2801-ADVSECURITYK9-M), Version 12.4(3f) installed. It doesn't seems to support BGP. Which feature sett do i need?
dgahm
Level 8
Level 8
I just logged into a 2821 running BGP and it has IOS C2800NM-ENTSERVICESK9-M), Version 12.4(10)
c2800nm-entservicesk9-mz.124-10.bin
Please rate helpful posts.
spremkumar
Level 9
Level 9
In addition to David's comment you can always refer feature navigator tool for finding out the rite ios which can support the required features ..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
aceadmin
Advanced Security images started carrying BGP in 12.4.9T I believe. Check the Feature Navigator to be sure.
Brian
Friend,
unfortunately the 12.4(3f) does not support BGP with advance security feature.
I suggest to any 12.4T train image or better upgrade to advance IP services image
HTH, rate if it does
Narayan
