Block the Branch Router HTTP webpage from being seen on the outside WAN ip address
Mike Johnson
How do i block/prevent the router webpage from opening/access at the WAN outside ip address when http server is enabled?
alessandro.s
Hi Mike,
you can create an access list denying unwanted traffic then apply to http access with the command :
ip http access-class [acl-number]
hope this helps.
