Cisco Router 2900 not able to access any DSL commands for ADSL2/2+ or 1ADSL
Mike Johnson
When i enter configuration mode for ATM any DSL commands are not recognized. Believe i have the right IOS. Any suggestions will help.
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
vpdn enable
redundancy
controller VDSL 0/1/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 218.12.1.1 255.255.255.0
ip nat inside
no ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ATM0/1/0
no ip address
atm bandwidth dynamic
no atm ilmi-keepalive
pvc 0/35
pppoe-client dial-pool-number 1
interface Ethernet0/1/0
no ip address
shutdown
no fair-queue
interface GigabitEthernet0/0/0
no ip address
interface GigabitEthernet0/0/1
no ip address
interface GigabitEthernet0/0/2
no ip address
interface GigabitEthernet0/0/3
no ip address
interface Vlan1
no ip address
interface Vlan6
no ip address
interface Dialer1
description hwic1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
keepalive 300
ppp chap hostname @ATT.net
ppp chap password 0
ppp pap sent-username @ATT.net password 0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 218.12.1.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
scheduler allocate 20000 1000
anisaini
check your config/hardware
"controller VDSL 0/1/0"
its a VDSL and not ADSL, for the option that you are looking for are available depending on the card , some cards are VA which has VDSL as well as ADSL some are just V(ie VDSL)
Hence check what your current hardwar is or what you are looking for.
http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/vdsl2_hwic.pdf
Jose Bogantes
Hi Mike,
What command are you trying to type? Are you trying to enter the "operating mode" command? We have to remember that you have a VDSL controller (probably an HWIC-1VDSL); therefore, the you should make changes under the controller VDSL. Please provide more details on the commands that are not being recognized.
Regards.
anisaini
