BRI Configuration as Backup link.
Does anyone know if we setup back-2-back BRI using 2x WIC-1B-S/T-V3 ?
Using 2901 router.
dojoy
Using the WIC-1B-S/T-V3 Interface alone you wont be able to simulate the back to back.
Reason: WIC-1B-S/T-V3 does not emulate as network.
e.g. : isdn layer1-emulate network Command wont work.
You will have to use an NT/TE Interface to simulate a ISP Side. This interface can support voice calls. Not data calls.
Below is the minimum commands required for the ISDN link to come up.
NT/TE Interface:
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn skipsend-idverify
end
S/T Interface:
interface BRI0/2/0
no ip address
end
Hope this helps.
Anyone..?
paolo bevilacqua
Likely not, but you can check if you can configure the isnd network side commands.
dojoy
NT/TE Interface:
interface BRI0/1/0
no ip address
end
S/T Interface:
interface BRI0/2/0
no ip address
end
Hope this helps.
