c1111 router licensing
nareh84
Level 3
Level 3
hi
we have got C1111-8PLTELA with ipbase and security license. the firmware which was with the router supported only smart license. because of that we downgraded to c1100-universalk9_ias.16.09.02.SPA.bin. when we check show license, i can see security as permanent but nothing under ipbase. do i have to get PAK for ipbase if i have to get it permanently activated?
#show license
Index 1 Feature: appxk9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Count: Non-Counted
License Priority: None
Index 2 Feature: securityk9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
Index 3 Feature: ipbasek9
Index 4 Feature: FoundationSuiteK9
Index 5 Feature: hseck9
Index 6 Feature: throughput
Index 7 Feature: internal_service
balaji.bandi
The license key for the ipbasek9 package is activated by default. - is this output after upgrade or before upgrade to 16.9.X ?
also can you post :
show license summary
show license all
show license status
show ver
BB
--> c1100-universalk9_ias.16.09.02.SPA.bin
This translates to release Fuji-16.9.2 ED, for which SmartNET is still mandatory. If you want to use Right-to-use licensing, you need a 16.8 release.
hi
find the attached output of license commands
the firmeware which came with router only supported smart licensing and i think this require dna based licensing? so i have downgraded firmware but i can only see security feature license is permanent but not ipbase
Thx
balaji.bandi
You should see as below : (but looks something went wrong after upgrade, or something not correct while you doing smart License)
Quick to resolve is contact license@cisoc.com they are very quick and get you right
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
1#show license all
License Store: Primary License Storage
StoreIndex: 0 Feature: ipbasek9 Version: 1.0
StoreIndex: 2 Feature: securityk9 Version: 1.0
BB
