cannot ping
korbenda11as
from 10.209.19.234 next hop 10.209.19.235 to 10.209.19.51 can ping.
from 10.209.19.234 next hop 10.209.19.235 to 10.209.19.65 cannot ping, why?
pls. see attachment drawing ....thanks!
6 Replies 6
royalblues
Level 10
Level 10
Do you have route for the subnet 10.209.19.65 on the router with IP 10.203.19.234?
can you post the routing table from both the routers
Narayan
yes i do have route...i did a traceroute from 10.203.19.234 to 10.203.19.65 and it stops at 6506 switch. I add a static route with vlan3 as my next hop and it works. Do I really need to add static routes on the switch? or can I just enable dynamic routing protocol (e.g. rip) on the switch? Pls. advice....thanks!
From your post i understand u dont have route on core switch to the subnet to which host .65 is connected. So u nned to add a route.Running a protocol is entirely your choice.
thanks, can you give me a link for example configuration using dynamic protocol on a switch...
s.arunkumar
Level 3
Level 3
check for any sort of filtering via access list...
check for route entry for subnet of 10.209.19.65..
Rick Morris
Level 6
Level 6
This may be a stupid question, but is the interface up?
Can you ping the IP from the switch connected to that interface?
Can you do a traceroute to the IP and see where it dies at, then on the router where the .19.65 address is at do a debug icmp trace and capture the icmp to see if there is any ack back?
