Cannot see 2600 router through catalyst 2950 switch
lang1armean
New to Cisco so please bare with me. I am having trouble  connecting the Cisco 2600 to the Catalyst 2950. All ports on switch are set to Vlan 1 and show status as being connected except those not connected to anything of course. However, Interface Fa0/1 is showing NOT connected with the router connected to it.
I have reset the switch:
flash_init
load_helper
boot
then i configure IP address and Gatewway, but still show status as "not connected"
Looking for a starting point please.
Much Appreciated,
Mark L
18 Replies 18
You're Welcome Mark! Glad to hear that it is working.
If you get (or make) a rolled T1 cable, you can connect two of your routers to each other's T1 ports, and on router 1's ethernet port can connect to the Internet connection, while the other router goes to your switch as you have it set up now. This will require some configuring, but is cheaper than buying a card.
I am including a drawing to help show what I mean.
Good Luck!!
There is an easier way:
Create a seperate Internet VLAN on your switch (assuming vlan 1 is your plain data VLAN): e.g. vlan999.
Setup fa0/24 as follows:
int fa0/24
 description ** Internet **
 switchport mode access
 switchport access vlan 999
 spanning-tree portfast
Create a trunk port for the router
int fa0/23
 switchport mode trunk
Setup a trunk port on the router:
int fa0/0
 no ip address
fa0/0.1
 encapsulation dot1q 1 native
 ip nat inside
int fa 0/0.99
 encapsulation dot1q 99
 ip address DHCP
 ip nat outside
Setup NAT
ip nat inside source NAT-ACL interface fa0/0.99 overload
ip access-list extended NAT-ACL
 10 permit ip 192.168.1.0 0.0.0.255 any
What this solves is your lack of ethernet ports on your router by using some of your switch ports.
i did get the network connection working from routers eth port to the switch and can ping the router
Oops - very sorry that I missed this, but it didn't hit me until the drive home. I just verified that this works from my lab.
The issue is that your switch is running as a layer 2 device, so if you are going to layer 3 from layer 2, it has to have an IP that it can get to on that VLAN at layer 3. Hence you need to configure your uplink to the router as a trunk port, not a switchport on the switch. And you need to configure the VLAN on the router using a sub-interface and VLAN ID of 1. Hope this makes sense....
Here are the configs
Switch
interface FastEthernet0/1
 switchport trunk allowed vlan 1
no ip default-gateway 192.168.10.25
your other interfaces would be access ports and vlan 1, or just access if you have no other vlans
interface FastEthernet0/3
On the router, you configure the sub-interface and vlan info as follows:
interface FastEthernet0/0.1
 encapsulation dot1Q 1 native
 ip address 192.168.10.25 255.255.255.0
if you decide to add another VLAN later, just put in:
interface fa0/0.5
encapsulation dot1q 5
ip address 192.168.5.1 255.255.255.0
and on the switch you simply modify your trunk port line
  switchport trunk allowed vlan 1, 5
then assign access ports to VLAN 5 as needed
Hope this helps and sorry for the other post - please disregard
p.s. As a security precaution, it is good practice to not use VLAN 1 - many places I've worked at do not use it, and instead use other VLANs. They shut down VLAN 1.
