Cat 4500 GRE Tunnel performances
helenio
Hello, I have som performances issues with a GRE Tunnel on 4500 (12.2(37)SG with Supervisor V).
I think that GRE Tunnel is performed on SW, isn't ?
Does someone know the max throughput that we can get on that tunnel ?
I'm afraid that fragmentation can also decrease the performances, ho can I check the number of fragmented packet on that tunnel ?
8 Replies 8
Hitesh Vinzoda
Level 4
Level 4
hi,
Its true that GRE packets are process switched in 4500 series switches running with any codes  i.e Switched in software. I think it will give you performance between 5 to 15 Mbps at max. It may also lead to high CPU utilization during the specified data rates.
Hitesh Vinzoda
Giuseppe Larosa
Hello Helenio,
use of GRE tunnels on a Cisco 4500 is not recommended it would lead to very high cpu usage with rather poor performances.
We also noticed that is not possible to move traffic in a VRF using a GRE tunnel in VRF.
What is your scenario?
Hope to help
Giuseppe
I'm using GRE tunnel cause I have to set up a EIGRP comunication over VPN-IPsec (2x Fortigate FWs). I did a test and I had 70% CPU with 40 Mbps traffic.
Do you see another way to establish a EIGRP Neighborship trhough a VPN IPsec Tunnel ?
For the VRF you mean that you can't assign a Tunnel to a VRF other that the Global one ?
As Giuseppe mentioned above, you must use router not switches for tunnels.
Where can I fing Tunnel performances based on RTR Model ?
Hello Helenio,
use the following PDF, a newer version exists including new G2 ISR routers.
Hope to help
Giuseppe
Thank's ... Tunnel GRE in Routers is done in Fast/CEF ? ...
Hello Helenio,
yes sw based routers have no dramatic performance penalties when handling GRE tunnels.
CEF for tunnel GRE should be supported in recent IOS releases
Hope to help
Giuseppe
