Catalyst 3850 + MPLS L2VPN
Leonid Voronkin
Hi, community.
Has anyone used MPLS on Catalyst 3850. I want to know your impression. In particular about VPLS. How does it work? Have you noticed any underwater rocks or issues?
________________________________________________________
Если ответ понравился, ставь звёздочку. Если ответ помог решить твою проблему, утверди его в качестве решения
5 Replies 5
balaji.bandi
3850 has MPLS support, again depends on what you like to use and where is the question.
Other suggestion, i would suggest to use Cat 9300 instead of Cat 3850 for Longer ROI Point of view, since cisco more focussing on Cat 9K Models
here is more reference :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-6/configuration_guide/mpls/b_166_mpls_9300_cg/b_165_mpls_9300_cg_chapter_011.html
BB
I know that MPLS supports on Cat 3850. I am interested to get feedback from real cases.
Of course but we have already have Cat 3850
As of now we did not see or encounter any issue around MPLS/VPLS, but by saying that not every enviroment is the same.
BB
Leonid Voronkin
Really no one deployed MPLS on Cat 3850?
I too am interested to hear if anybody has had any issues? Currently router(2911) on a stick approach at a location and our ISP has suggested we us VPLS to gain more bandwidth by plugging directly in to the 3850. Any QoS considerations or issues?
