DHCP over GRE tunnel
RexChang32809
I'm preparing a environment that CPE can obtain IP address via GRE tunnel. For that purpose, I simplified my environment as below topology.
And here's my running-config of two Cisco router(C1111-8P).
Cisco Router (R1):
Building configuration...
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
no aaa new-model
ip dhcp relay information option
subscriber templating
vlan internal allocation policy ascending
interface Tunnel1
ip address 10.10.10.1 255.255.255.0
ip helper-address 10.11.12.1
keepalive 10 3
tunnel source GigabitEthernet0/0/0
tunnel destination 192.168.7.14
interface GigabitEthernet0/0/0
ip address 172.51.37.222 255.255.255.0
negotiation auto
interface GigabitEthernet0/1/0
switchport access vlan 10
interface Vlan1
no ip address
interface Vlan10
ip address dhcp
ip forward-protocol nd
no ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
end
Cisco Router (R2):
version 16.6
hostname Router
boot-start-marker
boot-end-marker
interface Tunnel1
ip address 10.10.10.2 255.255.255.0
keepalive 10 3
tunnel destination 172.51.37.222
ip address 192.168.7.14 255.255.255.0
negotiation auto
interface Vlan1
ip address dhcp
ip http server
ip http authentication local
ip route 0.0.0.0 0.0.0.0 Tunnel1
ip route 10.11.12.0 255.255.255.0 Tunnel1
ip route 172.51.37.0 255.255.255.0 GigabitEthernet0/0/0
end
For now, I can ping from R2 to my DHCP server. However, despite my GRE tunnel is established, my client cannot obtain IP address via GRE from DHCP server. I observed received packets at DHCP server and there's no DHCP Discover sent by my client.
Could any one help me with this?
BR,
Rex Chang
Cristian Matei
   You have a chicken-egg issue here:
    1. I see that also the R1gets an IP address from the DHCP server, which is directly attached to its VLAN10; this is gonna work, as long as you have DHCP pool defined on the DCHP server, for local VLAN10 associated IP subnet, because the DHCP server is directly connected, it sees the DHCP client broadcast messages.
    2. I see that the remote router, R2, also has its VLAN1, the inside interface, configured for DHCP; this would work as long as the DHCP server would be locally in that VLAN. R2 , by design of DHCP, cannot pick its own DHCP Discovery packet and send it as unicast to the remote side where the DHCP server resides (the DHCP Relay function). So put a static IP address on VLAN1
   3. For DHCP clients behind R1 to get an IP address via the DHCP server behind R2, you need to ensure that VLAN10 and VLAN1 IP subnets are routable end-to-end, between the DHCP Server and the DHCP Relay Agent (R2).
       I cleaned your config, test it, it's gonna work, as long as you have another DHCP pool defined on your DHCP server, for VLAN1 IP subnet behind R2, and in the DHCP pool you configured the default gateway to be the IP address of R2 VLAN1 (10.11.13.1). I assume that 10.11.12.1 is your DHCP server, and R2 inside subnet is 10.11.13.0.24.
R1:
no ip dhcp relay information option
 no ip helper-address 10.11.12.1
interface Tunnel1
ip route 10.11.13.0 255.255.255.0 Tunnel1
R2:
interface Tunnel1
interface Vlan1
no ip address dhcp
ip address 10.11.13.1 255.255.255.0
Cristian Matei.
Mark Elsen
 - Check the observed advisories from thee threads :
     https://community.cisco.com/t5/routing/dhcp-ip-via-gre-tunnel/td-p/2481767
     https://community.cisco.com/t5/routing/dhcp-relay-through-gre-over-ipsec/td-p/1622333
 M.
Cristian Matei
R1:
interface Tunnel1
R2:
interface Tunnel1
interface Vlan1
no ip address dhcp
Cristian Matei.
That did work. Thanks for your patience and help!!! You saved my day.
Best regards,
Rex Chang
