Sa-VAM2 Module not detecting in Cisco 7204VXR
srihari1986
Totay we tried to install a SA-VAM2 module in our Cisco 7204VXR/NPE 400 router but it did not work.  We keep getting the  error message
        Port adapter is disabled unsuitable deactivated powered off. Any idea on what is causing the problem? I have already upgraded the router to a high IOS than the module required. Is it the problem with the hardware revision of the module and the chassis? THe module is 3.0 and the chassis is 2.6
Slot 3:
        VAM2 Encryption/Compression engine, Port adapter
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware Revision        : 3.0
        PCB Serial Number        : JAB100604CS
        Part Number              : 73-8491-04
        Board Revision           : A0
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Deviation Number         : 83050
        Product (FRU) Number     : SA-VAM2
        Top Assy. Part Number    : 800-22836-03
        CLEI Code                : CNUIAR7AAA
        Version Identifier       : V02
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 03 E4 41 03 00 C1 8B 4A 41 42 31 30 30
          0x10: 36 30 34 43 53 82 49 21 2B 04 42 41 30 03 00 81
          0x20: 00 00 00 00 04 00 88 00 01 44 6A CB 94 53 41 2D
          0x30: 56 41 4D 32 20 20 20 20 20 20 20 20 20 20 20 20
          0x40: 20 C0 46 03 20 00 59 34 03 C6 8A 43 4E 55 49 41
          0x50: 52 37 41 41 41 89 56 30 32 20 FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
SH Version
Cisco IOS Software, 7200 Software (C7200-ADVIPSERVICESK9-M), Version 12.4(22)T5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Apr-10 13:31 by prod_rel_team
ROM: System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.1(8a)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
System image file is "disk0:c7200-advipservicesk9-mz.124-22.T5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7204VXR (NPE400) processor (revision A) with 491520K/32768K bytes of memory.
Processor board ID 26800277
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
4 slot VXR midplane, Version 2.6
Last reset from power-on
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb0_mb1 has a total of 400 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4, 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
2 FastEthernet interfaces
8 Serial interfaces
125K bytes of NVRAM.
125440K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
Rozsa Illes
Hello Srihari,
Try to upgrade the boot loader to the same version as the IOS. You are running 12.1(8a)E and I have seen that older bootloader images can cause difficulties with recognizing newer modules.
If it is still not recognized, could you upload the full boot logs along with a fresh show ver and show diag?
Warm Regards,
Rose
