CBS350-8T-E-2G inter vlan routing
Hi There,
Needing help with inter vlan routing on CBS350 layer 3 switch.
Looking thru the manual was no help. The term inter lan routing is not found. I was wondering if this model doesn't have this ability. Any insight would be great.
Thanks in advance.
Tony
Richard Burts
Tony
The documentation for the CBS350 is fairly clear that it should support ip routing (which should include inter vlan routing though it might not use that exact name to identify it. Perhaps you could tell us a bit more about this switch, which version of software is it running? what license does it have?
The manual I was looking at has a chapter on IPv4 Configuration. Does your manual have a chapter like this? Have you tried the steps identified in the chapter?
Rick
you need to make sure switch is in L3 mode and it will automatically enable routing. then you can configure vlan interfaces and ip addresses.
Good luck
KB
Thanks, I will do that when I get back to that project. Appreciated!
KJK99
Level 3
Level 3
@anthony tuccillo
It's IPv4 Routing under IPv4 Configuration>IPv4 Interface in the GUI admin.
Kris K
