Cisco 1100
NotKnown12880
VIm trying on my desk to configure two Cisco C1117-4PM connected to eachother using the vdsl interface on a standard telephone cable.  Running 16.12.03 image.Routing
I've read the configuration  information regaring setup of these controller, but all documentation refers to connect to ISP DSLAM.
I cannot get the interface up, Im starting to believe I have missed some information or these two units cannot initate DSL connection together.
show controllers vdsL 0/2/0
Controller VDSL 0/2/0 is DOWN
Daemon Status: TRAINING
XTU-R (DS) XTU-C (US)
Chip Vendor ID: ' ' ' '
Chip Vendor Specific: 0x0000 0x0000
Chip Vendor Country: 0x0000 0x0000
Modem Vendor ID: ' ' ' '
Modem Vendor Specific: 0x0000 0x0000
Modem Vendor Country: 0x0000 0x0000
Serial Number Near:
Serial Number Far:
Modem Version Near:
Modem Version Far:
Modem Status: Line NOT intialized
DSL Config Mode: VDSL2
Trained Mode:
TC Mode: UNKNOWN
Selftest Result: 0x00
DELT configuration: enabled
DELT state: in progress
Failed full inits: 0
Short inits: 0
Failed short inits: 0
Modem FW Version:
Modem PHY Version:
Modem PHY Source: System
Training Log : Stopped
Training Log Filename : flash:vdsllog.bin
 Please advise
\\tor
what are you trying to do, connect two C1100 routers back to back using VDSL ? That won't work, you need a DSLAM in between. Which you don't have, that is why the documentation is referencing the ISP.
balaji.bandi
Whose is the provider and can you post fill configuration to look, some provider look vlan tagging.
EDIT
@Georg Pauwen  - i was in imression user looking to connect to provider, you right, if the back to back it will not work. cheers.
BB
Yes, exactly what I am trying to do. Im fairly experienced in networking, but not setting up dsl connections. I got the devices from our supplier in a Cisco Try&Buy order and will probably return them because of this limitation. Is the similar limitation using xDSL feature as well?
I need a solution using Cisco as these are standard devices supported by our organization. Is there a fairly not-to-expensive solution for a back-to-back(master/Slave) configuration using Cisco?
\\Tor
