07-12-2011 07:55 AM - edited 03-04-2019 12:57 PM
hello world !
i set up a CISCO 1811 as routeur for different vlan's
but it appear that i can't add a new vlan i'm limited to 14
all vlan trunked on a iface (Fast0) and just one vlan untagged to another iface (Fast1) go to gateaway
i manage routing access with ACL_ip
do you know a model from cisco let me do it for more thant one undred vlans ??
regards,
07-12-2011 08:03 AM
For inter-vlan routing, use L3 switches, not routers.
For example, an 8 ports 3560.
07-12-2011 08:15 AM
ok
but i have some problems by using L3 swithing routing facilities
it has just one Mac addr so it will loop and storm my network
if i plug much one port ..> to an existing swith witch provied trunk
and gateway port
07-12-2011 08:28 AM
You are doing somethign wrong.
Either your network is not configured correcly or you are not using L3 switch the correct manner.
They do not cause any problem ever and do not storm any network.
Furthermore thye do not have only one MAC address as you say.
