Cisco 1841 Fas 0/0 Interface UP porotocol Down
singhsaju
Level 4
Level 4
I am replacing a cisco 1751 router with the new 1841 router.
The WAN side is UP/UP. The fastethrenet side is UP/DOWN. The speed is auto and duplex full. It is configured the same as it was in Cisco 1751.
The Fas 0/0 connects to 3COM switch. The LED on 3com switch is off when 1841 is connected.But on 1841 the LED for fas 0/0 is green.
Any ideas what is happening here?
5 Replies 5
paolo bevilacqua
Try hardcoding speed and duplex.
I have already tried hardcoding speed/duplex. The interface is still UP/Down.
That is strange, other than trying other IOS I wouldn't know what to suggest. Perhaps the TAC has information on the issue.
bmcginn
Level 3
Level 3
Have you replaced the patch cable?
Try a ethernet loopback plug in the Router ethernet port. See if it comes up.
