07-16-2007 08:21 PM - edited 03-03-2019 05:53 PM
Dear Community
I want to run OSPF Version 3 on my Cisco 2620 router, But I could locate the IOS from Cisco Web Site.
Any body can guide me through?
Thanks in advance....
Kelvin Cheung
07-16-2007 09:20 PM
Have you tried using Software Advisor tool ?
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
07-16-2007 09:29 PM
kelvin,
The least IOS which has support for OSPF V3 (IPv6 routing) for the 2620 is in 12.3(3c) IP plus software.
Unfortunately the requirement is minimum 32MB flash and 64MB DRAM.
Use the Feature navigator
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH, rate if it does
Narayan
07-16-2007 09:53 PM
Dear Narayan
what is the old IOS that support 16M Flash and 64M DRAM?
Regards & Thanks
Kelvin Cheung
07-16-2007 10:06 PM
What feature set are you looking for?
You can go through the feature navigator link which i was provided earlier.
Narayan
