12-03-2018 02:05 PM - edited 03-05-2019 11:05 AM
Hello:
Currently we have router 2811 and after I add a second WIC Gig ethernet card and for someone how I can't bring it online or it not allow me to configure the card.
Here is version of the router:
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 15.1(4)M10, RELEASE SOFTWARE (fc2)
Show diag:
WIC Slot 2:
1 Port Gigabit Ethernet SFP/Copper EHWIC
WIC module not supported/disabled in this slot
PCB Serial Number : FOC20133QX2
Hardware Revision : 1.0
Part Number : 73-13295-01
Board Revision : A1
Top Assy. Part Number : 800-34350-01
Deviation Number : 0
Fab Version : 05
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : EHWIC-1GE-SFP-CU
Version Identifier : V01
CLEI Code : CMUIAA8CAA
Unknown Field (type 00D4): CC
Asset Identifier : A0
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 32 30 31 33 33 51 58 32 40
0x10: 06 A3 41 01 00 82 49 33 EF 01 42 41 31 C0 46 03
0x20: 20 00 86 2E 01 88 00 00 00 00 02 05 03 00 81 00
0x30: 00 00 00 04 00 CB 90 45 48 57 49 43 2D 31 47 45
0x40: 2D 53 46 50 2D 43 55 89 56 30 31 00 D9 03 40 C1
0x50: CB C6 8A 43 4D 55 49 41 41 38 43 41 41 D4 82 43
0x60: 43 CC 82 41 30 FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Any help will appreciate it.
Thx,
Hiep
12-03-2018 02:32 PM
WIC module not supported/disabled in this slot - as per it says not supported,
can you post
show version
show modules.
12-03-2018 02:33 PM
have you looked at this compatible guide for - EHWIC-1GE-SFP-CU
12-03-2018 02:35 PM
The version of this router is in the email And show modules is invalid
12-03-2018 02:37 PM
I follow that link and the command is invalid when I insert this in
belrtr(config)#interface ethernet 0/2/0
% Invalid input detected at '^' marker.
belrtr(config)#
12-03-2018 03:07 PM
Heip,
Here is the answer to your issue:
WIC Slot 2:
Sorry, but this WIC isn't supported in the router.
Joe
12-03-2018 03:12 PM
Do you know if this card will support other slot like 0, 1 or 3? If not can you tell me which card will support fru or part number. If you can provide me a link for the card.
12-03-2018 03:22 PM
As i was pointed this module EHWIC-1GE-SFP-CU is not support for your device 2811
12-03-2018 03:23 PM
Do you know which module or wic card will support this router.
12-03-2018 09:34 PM
EHWIC-1GE-SFP-CU is only compatible with the ISR G2. The 2811 is an ISR G1.
For a ISR G1, you need to look at HWIC-1GE, however, you need to pay attention to the Data Sheet (Table 3) because there is a limit of how many HWIC-1GE is supported.
It is also very important to note that a 2811 does not have the CPU to push beyond 61.44 Mbps.
12-04-2018 08:08 AM
12-04-2018 11:01 AM
Do you know what is the part or fru number for this module. So I can get a quote from our vendor.
Thx,
12-04-2018 02:01 PM
As suggested all the replies, your 2811 not capable of taking Gig port, what module you looking to buy ?
if you looking gig capabilities, you need to get upgrade from 2811 to next level which can offer Gig port.
12-04-2018 02:10 PM
I just want to add another Ethernet module on this router so I can use it as a backup internet.
12-04-2018 02:46 PM
